Max Ballast weight in my 78 |
horkn ![]() Platinum Member ![]() ![]() Joined: September-10-2007 Location: Cedarburg, Wi Status: Offline Points: 1511 |
![]() ![]() ![]() ![]() ![]() Posted: August-15-2010 at 12:57pm |
My 78 martinique has the same hull as your SN.
I usually add 1 large (600 lb IIRC) fat sac in place of the rear seat bottom, but I have added two, one bigger and one smaller 350 lb side sac in back. If I had 2 side sacs, I would have probably tried that combo too. Now I do have a redone floor, all plywood and it's definitely heavier than the stock stuff was. I did even run a fat sac or 2 when I ran it for a brief time before redoing the floor and interior. You'll be fine. |
ncdoubleup ![]() Senior Member ![]() ![]() Joined: August-08-2010 Location: Statesville, NC Status: Offline Points: 164 |
We had a 78 and ran 2 fat sacks and never had any problems. The floor and the stringers were new, but never had any problems. They will create a fantastic wake.
Good luck, have fun & be safe!!! |
petermuhic ![]() Groupie ![]() ![]() Joined: July-13-2010 Location: Toronto Ontario Status: Offline Points: 50 |
alright,, thanks,, i know the newer boats alot of guys run with bags but i havent seen the older ones with it. Cause i want to produce a bigger wake for wakeboarding..
Oh and johny law doesnt affect me on the small lakes i wakeboard on, we dont hit the bigger lakes cause the small ones are more private, secluded, usually GLASS and have no cops, they have no reason to be there really. just wanted to know if the boat can handle it. |
bkhallpass ![]() Grand Poobah ![]() ![]() Joined: March-29-2005 Location: United States Status: Offline Points: 4723 |
You'll be fine. Lots of people running sacs on both sides of the motor box.
If you want to see the construction under your floor, do a search on stringer repair threads. A there have been a couple on boats of your vintage and you'll see what it looks like under there from the factory. BKH |
Livin' the Dream
SN206 ![]() Grand Poobah ![]() ![]() Joined: February-25-2009 Location: Fort Worth, TX Status: Offline Points: 2339 |
Some people have, some people think it not necessary. I think your talking about 766.1 lbs of addition, which would be pushing if not exceeding reccomended total combine weight. Johny Law looks for things like that. It's your vessel and you're the Capt., so do what you want. |
has anyone ever used these weight bags on there older ski nautiques?
i was just wondering, i am thinking of buying a ballast fat sac kit for my 1978 ski nautique, it contains a two bag set up/ Each bag is 60" long and 15" in diameter. i was thinking of putting one bag on each side of ther motor to weight down the boat for a bigger wake. Each bag weights 350lbs,
what im asking is,, do you think its a good idea to have these bags sitting on the stringers? because i have never openeed up the bottom of my boat, it seams very solid but i have no idea of how it is constructed and if it can take that weight.... thanks.. any input would help./ |
