gel coat |
ky82sn
Senior Member Joined: December-05-2010 Location: Finchville,KY Status: Offline Points: 201 |
Posted: January-17-2011 at 1:56am |
i appreciate the info as well. i have a couple spots on my 82sn that need repaired.
1982 ski nautique
1966 Al Tyll Skier |
jeffcole14
Newbie Joined: January-11-2011 Location: tuscaloosa, al Status: Offline Points: 2 |
thanks for your advice, I'll try it. jeff
BuffaloBFN
Minicraft of Florida should have an exact match in small amounts. They have my '88 so I would expect them to have your boat as it's newer.
Jeff,
Gel kits are available in several sizes and by a couple name brand manufacturers. They contain pigments to color the base gel to the color needed. On line or your local marine supply will have them. The trick is matching the color!! Use extreamly small amounts of the pigment untill you get it correct and then add the hardener. Welcome in CCfan. |
jeffcole14
I need a small repair kit for gel coat on my 1991 sport nautique which is Teal in color. A dealer referred me to spectrumcolor.com, but they only had a gallon of teal for $350. I only need about 4oz. Thanks
