ACME prop dilema |
captan1
Senior Member Joined: June-02-2004 Location: United States Status: Offline Points: 180 |
Posted: July-28-2005 at 9:48pm |
steelerguy, what are you putting that prop on?, 470 is a 12 1/2 x 15 right?
steelerguy
Guest |
I just got my 470 Acme prop in the mail and put it on tonight. I wil be testing her out all week as I leave for vacation On friday....
SS 201
Senior Member Joined: October-20-2003 Location: United States Status: Offline Points: 232 |
Older CC had the props too close to the rudder, and too far from the strut in turn causes vibration. They finally in 1997 put the props 5/8 in from the strut and goodbye vibration.
79nautique
ultrashots, If you are having a noise/vibration problem with the ACMe prop, then there are a couple of things that need looked at. First the shaft alignment needs fixed/checked and if it is ok then you need to replace the prop shaft because there are to many hours on the shaft and it's going to break. Just my .02
David F
Well for what I did the first time out (i.e. mild acceleration until I am certain nothing goes wrong after restoration) I am certain I am am going to be extremely happy with the ACME #422. Acceleration was brisk, throttle response excellent.
ultrahots
Gold Member Joined: September-08-2004 Location: United States Status: Offline Points: 618 |
Like a Whine on accel and decel.
Darrel
Guest |
I have the #422 4 blade on my 95SN and it runs great, vibration free, quicker out of the hole than the orig. OJ 3 blade and about the same top speed. However, i would listen to the guys at acme, they really like the new 3 blade they recently came out with. Get them to send you both, try them and keep the winner, just let us know how they each performed on the 91 hull.
Ride_Klein
Newbie Joined: May-03-2005 Location: United States Status: Offline Points: 17 |
I'll vouch for the Acme. My experience is all on a 1986 2001, but it was great.
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=1591&KW=acme+542 I called the folks at Acme and their advice was right on in my opinion. Good luck, and I hope you're as happy with your prop as I was with mine. |
HOLESHOT
Groupie Joined: July-08-2005 Location: United States Status: Offline Points: 47 |
david f let me know how it dose for ya .
IF IT HAS A SPARKPLUG I CAN FIX IT
David F
I went with ACME's advice and just mounted the #422 on my '93 SN with the TBI Pro Ski engine (285HP, I think). As I am just about to finish the restoration, I should have the boat in the water this weekend and will let you know what I think of the prop. However, I have nothing to compare it to.
S.T.
Groupie Joined: June-04-2005 Location: United States Status: Offline Points: 56 |
ultrahots,
What kind of noise are you talking about? I went to an Acme prop and didn't notice any unusual noise. |
ultrahots
I have an ACME 3 blade and an OJ 4 blade.The ACME makes more noise due to the rough cut they put on it but both are very comparible props.I like the power band of the ACME a little bit better (tows a little better) but the noise i could do without.
HOLESHOT
go with the acme, iv got 1 on my 82 and it works great for me. i use mine for wake boarding.
the acme dealer didnot lie about a thing . and i gained about 10 more mph. |
eklock
Newbie Joined: July-09-2005 Location: United States Status: Offline Points: 14 |
My boat: '91 SN w/PCM 240hp, 320 hrs, 14 x 16 Federal 3-blade.
Usage: Slalom, boarding and towables (kids only). What to gain with a new prop: Pulling heavy skiers or doubles from deep water starts, someday I'll barefoot so I don't want to loose too much if any top end. DIM advised me to get a #422 4-blade and ACME advised me to get a #470 3-blade. Any comments or opinion? |
