  New Posts New Posts RSS Feed - turning prop by hand
skyway2k View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skyway2k Quote  Post ReplyReply Direct Link To This Post Topic: turning prop by hand
    Posted: February-16-2011 at 2:16pm
... if it feels like more than 2 fingers.. it's probably..
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-16-2011 at 9:59am
Originally posted by Warpman89 Warpman89 wrote:
should the prop continue to spin after you take your hand off it?
Stu,
No, not much. Even with some soap/water lubricating the cutlass bearing, there's always some drag. Also, you get drag from a properly adjusted packing gland.
Warpman89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warpman89 Quote  Post ReplyReply Direct Link To This Post Posted: February-15-2011 at 10:01pm
Stu
1982 BareFoot Nautique PCM 454 *Under Repair*
'82 BFN
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: February-15-2011 at 12:31am
Drcc, things were a little dull in your absence...Have you returned to stir the pot????
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-14-2011 at 10:25pm
Originally posted by harriss28 harriss28 wrote:
Should my '97 SN also turn with one finger?
Shawn
Shawn,
Yes, no matter what finger the DR. wants to use, it's the same.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: February-14-2011 at 7:15pm
Which finger should I use to obtain the optimum spin?
Is there a difference between a one, two or three finger spin?
harriss28 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote harriss28 Quote  Post ReplyReply Direct Link To This Post Posted: February-14-2011 at 7:03pm
Shawn
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-14-2011 at 4:56pm
It should spin easily with 1 finger. Sounds like you need to do an alignment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warpman89 Quote  Post ReplyReply Direct Link To This Post Posted: February-14-2011 at 4:51pm
How easily should the prop spin on my '75 ski nautique by hand? It takes some effort to spin mine and it will not continue to spin after I stop spinning it. And yes, my tranny is in neutral. Is this normal or should it be easy to spin?
Stu
'82 BFN
