  New Posts New Posts RSS Feed - Running Hot
Running Hot
66altyllskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 66altyllskier Quote  Post ReplyReply Direct Link To This Post Topic: Running Hot
    Posted: August-22-2005 at 7:06pm
Thanks '72 mustang, I pulled the hose off the tranny cooler and sure enough found quite a few chunks of impeller. She seems to hold steady at 200 while running flat out, better, but not perfect. Before we couldn't get 2 miles w/o having to back down to idle. Now we can cruise without a problem, I actually got to ski Saturday! Hopefully things still look good when i drop the thermostat back in. The engine's 39 years old so she may have a bit of buildup. Probably save me a bunch of trouble, thanks again, and glad to hear you're back up and running.
Lefty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lefty Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2005 at 1:05am
Turns out my problem was a bad ground to the dash. I ran a new ground back to the block and in doing so found that the original was badly corroded.
'72 mustang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote '72 mustang Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2005 at 5:03pm
Hope it works out for you. I either overheated it and didnt catch it soon enough or it was already done before I bought it in July but I ended up with blown head gaskets. Finally got it back together and it fired right up for me last night. Going for a test run after work today. It sure felt good to hear the engine start up after having it sit in my garage for a month. Anyways I would hate to see anyone go through what I did for something so simple. Newbie mistake on my part, didnt know to check for something like that.
72 CC mustang
73skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73skier Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2005 at 12:03am
would warmer water make any change in temps.My 73 goes from 160-180 but if I'm in the warmer part of the lake it might go to close to 200 see i have a power plant on my lake so it has hot spots. water temps could be close to 120 is that normal?
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2005 at 12:51pm
The trans cooler should be above the normal water line while the boat is at rest. Therefore, if you disconnect the water intake hose at the cooler, water should not enter the boat. The water will seek its own level in the hose which would be below the cooler. Just make sure you keep the end of the hose above the water line and not let it fall down into the bilge.
There is not a screen on the inlet, just the grille.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 66altyllskier Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2005 at 11:20am
Originally posted by '72 mustang '72 mustang wrote:
My engine was getting up to 200 at speed and would cool back down to 160 at 1k rpm. The trans oil cooler was clogged.
I'll take a look at that this week, it would be nice if I could find the fix without pulling her out of the water, thanks 72. Also, the water intakes in the bottom of the boat, is there an additional screen after the stainless looking water intake w/the slots in it or is that it? Can't say I've ever pulled them off the bottom of the boat.
thanks
Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote '72 mustang Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2005 at 3:08pm
72 CC mustang
HOLESHOT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HOLESHOT Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2005 at 2:31pm
my 82 did the same thing and it was the sending unit
IF IT HAS A SPARKPLUG I CAN FIX IT
Post Options Post Options   Thanks (0) Thanks(0)   Quote 66altyllskier Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2005 at 1:45am
Got a 66 Al tyll skier w/the same problem. Changed the impellers & thermostat, still jumpin up to 220. pulled the thermostat out and still getting all the way up, when I back her down to 1k rpm she cools right down. will update when I pin it down.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lefty Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2005 at 10:54pm
Originally posted by JoelH JoelH wrote:
Originally posted by skyhawkflyer skyhawkflyer wrote:
If you stuck in an automotive type stat those are different, usually 180 degree. Must be marine part.
Completely incorrect. The manifold is jacketed. Water runs inside the jackets and exhaust goes in the center. Only at the end of the elbows do exhaust and water mix. You can have water blocked and still get plenty of exhaust through.
When I removed the winterizing plug from the exhaust manifold I did get a significant amount of scale and rust out. After doing that the water runs clear and there seems to be the normal amount coming out of the exhaust. An other suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2005 at 12:35pm
Yes, you are absolutely correct and I agree.
JoelH View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoelH Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2005 at 2:04am
In post above, meant to quote David F, not Skyhawk. ^^^
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoelH Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2005 at 2:03am
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2005 at 8:00pm
I would replace the sending unit, just to rule out if it is really running hotter than before.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lefty Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2005 at 11:05pm
The thermo is a 140 marine. All strainers are clean. How do I check for rust in the exhaust manifold without a tear down. The boat runs strong other than the overheat.
skyhawkflyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skyhawkflyer Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2005 at 6:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2005 at 5:22pm
If the water cannot get out of the exhaust, neither can the exhaust gases and the engine thereby would not run at all.
160 - 180 is normal range. Check the thermostat temperature set point.
mackwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mackwrench Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2005 at 5:17pm
Make sure you have no restriction in the exhaust, rust inside manifods, stopped up muffler etc..., all the water in the world won't cool it if it can't get out though the exhaust.
NO LONGER A MEMBER
Post Options Post Options   Thanks (0) Thanks(0)   Quote skyhawkflyer Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2005 at 4:47pm
Is your strainer clean? Did you stick in a 140 or 160 degree stat?.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lefty Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2005 at 4:03pm
Our 89, 2001 with a 351 PCM (530 hrs) started running hot last week. I shut her down after the gauge got to 200. After replacing the impellor and the thermostat she still runs warm at 180 (usually ran at 160). Any suggestions?
