source for speedo pitot |
Author | ||
Posted: March-16-2011 at 11:32am |
Ive heard the copper tubing upstream of the pickup (commonly mounted on the transom- usually on the inside) called ballast tubes and dampening tubes. Pickup = pitot. |
Swatkinz
Platinum Member Joined: December-03-2003 Location: Lexington, SC Status: Offline Points: 1307 |
I'm told that's called a ballast. My part is called a pitot, but ive always called them pickups. Pickup seems like the more descriptive term. |
Steve
2011 Sport/Air 200 Excalibur 343 2017 Boatmate Tandem Axle Trailer Former CC owner (77, 80, 95, 88, all SNs) Former Malibu owner (07, 09) |
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3896 |
Gary,
Yes, it was also at the parting of the Red Sea. Donald |
dwcar
Platinum Member Joined: February-11-2007 Location: Houston Texas Status: Offline Points: 1103 |
Isnt the pitot the piece that is between the pickup and speedo? Looks like you are looking for the pickup??
83Ski
You bought that one on the other thread Don? You bringing it to SJRR? I'm still looking for the one that was at Tommy Bartletts
[QUOTE=uk1979] Is this one Rare QUOTE] Yes,yes it is. It was used at Cypress Gardens,the '72 Olympics and was being restored for the 2016 Chicago Olympics. Alas since that bid failed,all restoration work has stopped. His loss is your gain! There is another one that was used in those venues and Tommy Bartlett's too,but has not surfaced yet |
Donald80SN
Two wrongs = minus two points.
Mine is 100% orginal. It was specialy made for the Chicago Summer Olymics that went to RIO. |
Swatkinz
keyword........."former" |
Steve
Keeganino
Grand Poobah Joined: October-27-2009 Location: North Carolina Status: Offline Points: 2063 |
This is what I meant but my wording is kind of confusing looking back at it. And english is your second language! |
1973 Skier |
MartyMabe
Grand Poobah Joined: February-21-2006 Location: High Point,NC Status: Offline Points: 3980 |
Former Malibu owner +10
Swatkinz
teak floor round fenders non original steering wheel shall I continue? |
Steve
Swatkinz
so if I replace the other side with a matching unoriginal, does your math deduct another point or cancel out the one point deduction? inquiring minds? |
Steve
Donald80SN
One point deducted.
Swatkinz
Gary, The plan is to use the new pitot by modifying the holes as Kapla discusses so that the holes in the hull are unaltered. I'll hang on to the original pitot and if some CC purist in the future has plenty of time to make such a repair as you mention then they can have at it. I just don't have the time to fiddle with that kind of thing, though it seems like a reasonable solution if someone has the time and is committed enough to the originality cause. Steve |
Steve
You could try to repair it.Go to a hobby shop or a Hobby Lobby etc and get a piece of brass tubing that fits the hose.Then drill out the pitot where the part broke off so that the tube can be glued in being careful not to use so much glue as to clog the hole.
kapla
drill holes in the new pick up to match the existing ones in the hull...don´t drill the hull...
also when putting the screws back in, put some 3M 5200 or 4200 sealant.... |
<a href="">1992 ski nautique
Keeganino
I read that you can use your existing holes and drill new ones into the new pick up.
1973 Skier |
Swatkinz
Hi Randall,
When removing the tube from the pitot, I broke the nipple off of the pickup. I ended up picking up the SKIDIM offering this afternoon. At $13.95 it seemed like a reasonable although not exact replacement. Thanks for the input though to all |
Steve
89Ski_Nautique
Senior Member Joined: May-26-2009 Location: Windermere, FL Status: Offline Points: 160 |
Steve,
An obvious question, what is wrong with your old pitot? Have you disconnected the hose and tried cleaning it out with air pressure (reverse direction) limited to 25-30 psi? I was able to clean out my existing pitot tubes and then ran new hoses from the pitot pickup, to stablizer tubes and to the speedometers. They work great now. Otherwise getting NOS Airguide pitot tubes like these is costly. |
kapla
NLA unfortunately...get some generic from any vendor....
DIXIECHICKEN
Senior Member Joined: September-21-2010 Location: Texas Status: Offline Points: 106 |
K sorry that was a little premature. Did a little research and it looks like they don't make them anymore.
GIG EM!!!
If its hurtin, soak it in cider!! |
Swatkinz
There's is a three hole. Looking for an exact replacement
Steve
DIXIECHICKEN
skidim
GIG EM!!!
Swatkinz
Steve
