Ski Brendella engine rotation |
footinmuppet
Newbie Joined: September-29-2008 Location: United States Status: Offline Points: 22 |
Posted: March-16-2011 at 11:59am |
Thanks for the info. I've been searching google for the correct engine rotation with no luck. Thanks again. Mark
bkhallpass
Well, according to the two prop guides I just looked at, Brendella is a LH rotation prop, which is std rotation, I beleive.
BKH |
Livin' the Dream
footinmuppet
The bad thing is, the boat came to me with no motor and no prop. Basically a hull, top deck and interior. I have both LH and RH 351 PCM's, I just have to decide which one to install. Thanks again, Mark
eric lavine
if you have a 1:1 transmission, look at your prop, it will be stamped R or L
footinmuppet
Hi, Does anyone know if a 1989 Ski Brendella has a RH or LH engine in it? I am guessing a standard rotating (LH) engine, but I'm not sure. Thanks, Mark
