  New Posts New Posts RSS Feed - cracked fiberglass around Pylon
tkenny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tkenny Quote  Post ReplyReply Direct Link To This Post Topic: cracked fiberglass around Pylon
    Posted: March-20-2011 at 11:24pm
I took the pylon out yesterday. It was caused by the sky pylons and loose u-bolts. Any suggestions on putting back the plate at the bottom of the pylon.
skicat2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat2001 Quote  Post ReplyReply Direct Link To This Post Posted: March-20-2011 at 6:02pm
Pete,
The pylon is tied to the stringers is in it? If it is lose or coming apart, he may have a stringer issue. Welcome
1985 CC 2001-SOLD
Lee Michael Johnson
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2011 at 9:31am
Originally posted by tkenny tkenny wrote:
The stringers are solid.
What did you do to determine this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tkenny Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2011 at 11:32pm
I will try to get it out in the AM . thanks
BFNSport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BFNSport Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2011 at 10:55pm
Do you want to save the pylon?
If so pull the factory pylon and extension in one piece then make up a sleve or half sleve that you can pound on.And use heat.
Glass repair Scuff and re-glass
Pics of bad area might help.
SN206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN206 Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2011 at 10:49pm
Post some pics, plenty of guys here who have worked that issue, but pics help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tkenny Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2011 at 9:37pm
Also tried heat gun and torch no movement at all
Post Options Post Options   Thanks (0) Thanks(0)   Quote tkenny Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2011 at 9:36pm
The stringers are solid. whats the best way to repair the base of the pylon
Post Options Post Options   Thanks (0) Thanks(0)   Quote BFNSport Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2011 at 9:31pm
If it is a 2 piece pole remove the top section get a pin through the center attachment and try and lift-n-twist. If that doesn’t work try a heat gun, not a torch.
For the glass repair you will want to look at more than just around the pylon. My first guess would be that the extension was not installed or maintained properly and had too much deflection. Probably what caused it to slip down the pylon and lock up.....
Secondly if the stringers have not been replaced they will be and therein lies the rub if the stringers are bad the pylon will flex like a mofo
Post Options Post Options   Thanks (0) Thanks(0)   Quote tkenny Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2011 at 9:12pm
I just purchased a 1988 Barefoot nautique The fiberglass around the botton of the pylon is separated . It has a sky pole on it now that I want to remove but it is stuck any suggestions on repairing the separation in the glass or removing the Aluminum Sky pole extention
Thanks
