  New Posts New Posts RSS Feed - Hard steering
Hard steering
dillon5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dillon5 Quote  Post ReplyReply Direct Link To This Post Topic: Hard steering
    Posted: April-24-2011 at 2:24am
Please see the link to my post back in January: http://www.correctcraftfan.com/forum/forum_posts.asp?TID=20274&title=steering-cable-replacement-on-a-95-sn--do-it
95 Nautique 351
fsz111 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fsz111 Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2011 at 8:11am
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2011 at 2:51pm
Originally posted by Scrawford Scrawford wrote:
2. Repack the rudder. You'll know if you need this if your boat is hard to turn under load. I replaced the cable and it steered great at an idle but P-turns took two hands. I brought it back to the shop, dropped the rudder, cleaned it with degreaser, then repacked it with fresh bearing grease. My wife can now steer the boat with her pinky. NOTE: Be careful when tightening the compression nut. It should be snug but not tight. And don't forget to reinstall a piece of security wire on the bolt.
Ahh, good info there. Mine was tough to turn under load last season, but really easy when idling. I assumed the cable was going but I think I have more the rudder issue.
Scrawford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scrawford Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2011 at 2:39pm
I went through this last spring on my '97. Save yourself the trouble and just do two things, you'll be glad you did.
1. Buy a new cable. You can buy the OEM one, however I just bought an off the shelf one and it worked great. Some talked that the stroke was different or that the extra .5' would cause a problem (neither was true in my case). For me it worked perfect and was less than half the cost of the OEM.
Eric
97 196 Closed Bow
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2011 at 6:04pm
Originally posted by LAKESIDE LAKESIDE wrote:
I noticed behind the steering wheel there is a gear assembly where the cable rides.Should this also be greased? I didn't see a grease fitting...Thanks
Dave,
If you find your cable to be good, then the helm "box" can be opened up, cleaned a regreased.
Brian is correct that the cables are prone to fail. If it's bad, I suggest going OEM (CC).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2011 at 5:31pm
Hi Lakeside,
The stiffness could be the cable itself. I think they are prone to seizure.
The manual for my boat said to turn the wheel back and forth every so often during lay-up to keep it from seizing. This wasn't an option for me since my boat is in offsite storage. I'll see how it is when I get it back.
If you can disconnect the cable from the rudder, and the wheel turns easy, then the stiffness has to do with rudder packing. If it it's still stiff when disconnected, it's the cable.
LAKESIDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LAKESIDE Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2011 at 3:31pm
Over the winter my 93 SN steering became pretty stiff. Last season i pumped grease in the rudder shaft just as general maintenance and had no problems. I am going to re-grease rudder but was wondering if there were any other places i should grease. I noticed behind the steering wheel there is a gear assembly where the cable rides.Should this also be greased? I didn't see a grease fitting...Thanks
93 Ski Nautique   SUCK MY WAKE
