brakes |
SNobsessed
Posted: June-06-2011 at 12:56am |
I tightened up the bearings 1 notch. I'll look for the camber again we we go boating tomorrow (I noticed it in the mirror). If it is still present, I will probably leave it.
I haven't hit anything so it must have always been there. The tire will rot out before I wearout the tread on the inside corner. |
SkiBum
Not the spindles, the axle itself was not at the proper camber. The fix was for them to remove the axle and put it in a press to get the proper camber. One of the indicators of the brake problem was that the inside of the tires were wearing more than the outside. From what I learned it is highly unlikely that a spindle would be misaligned without catastrophic failure. If the bearings are tight and the wheels are off camber, like you describe, you may have a problem? |
gun-driver
They would have to be extremely loose to lean your wheel.
I would get in there and check for bearing failure if your wheel is leaning. |
SNobsessed
Bill - Was the spindle bent in relation to the flange (mounting for the backing plate)? Just trying to understand this failure mode. I was noticing today that my tire seemed to be leaning in - may have loose bearings.
SkiBum
I recently replaced the backing plates (complete with shoes, springs, and wheel cylinders), hubs, and bearings on my MC trailer. Still had a problem with the hubs not spinning freely which led to over-heating the brakes. Took it to a trailer repair shop to discover that the axle was bent. They put the proper bend back into the axle which solved the problem. If you have tried everything else then a bent axle may be the problem.
malibud
Gold Member Joined: July-08-2009 Location: north carolina Status: Offline Points: 613 |
Ok I took that wheel off and put it back on all was OK... then all the brakes locked up and I took it all apart and relized that I had installed the brake away cable latch on backwards. so i now need to bleed them and try again. I replaced master cylinder and all the drum brakes with backing plates, shoes etc but not the drums they looked good . so we will see. luckly i caught it when the brakes locked up and it did not get too hot... I knew I was leaving myself open for jabs with a nautique on a Mc trailer but it is function over fashion got run what ya got
Nautiquehunter
Platinum Member Joined: December-31-2008 Location: Lake Lanier GA Status: Offline Points: 1010 |
Did you replace the wheel cylinders?
BuffaloBFN
I'll resist the MC jab and say that brake parts are cheap when you consider the job they do. 'Whole', if I get your meaning, should include drum turning or replacement.
malibud
I replaced the whole surge brakes on my double axle mastercraft trailer all is good except for one drum is getting hot. I took the wheel and hub off and adjusted it all the way in but that still wasn't enough I can turn the wheel but it still scrapes. Can I let it go and let the shoes wear so that they don't scrape (I was told some noise is normal)or do need to have the drum turned (but then I need to take the dust seals off hard to find replacements)? any ideas would be greatly appreciated
dan |
