  New Posts New Posts RSS Feed - Disgruntled Pilot Light
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: Disgruntled Pilot Light
    Posted: April-30-2011 at 1:12pm
Originally posted by bhectus bhectus wrote:
Originally posted by Jtonor1 Jtonor1 wrote:
My parents got a new gas hot water heater a few years ago and had a problem with the pilot light going out during the summer. The new one was closer to the ground than then old one and since it is in the attic and gets really hot up there during the summer, we live in Louisiana, the flame would use up all the oxygen in the small space underneath the hot water heater and go out.
This happens when there is not enough "make-up air" in the room. In this application they are better off with a direct-vent gas heater or they need to install a fan to blow more fresh air into the room.
Or better yet, get some ventilation in that attic. Without any, there will be even bigger problems than just keeping a pilot light lit. Have you ever seen mushrooms growing on roof rafters??? The complete roof framing was nothing but rot!!! Some of the rafters came down in two pieces when they did the R&R.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2011 at 12:35am
Originally posted by quinner quinner wrote:
Greg, bet this guy could help
Chris,how is a picture of you at a kinkey party going to help Greg?
bhectus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhectus Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2011 at 11:14pm
'87 Barefoot - sold
'97 Super Sport Nautique - originally custom built for Walt Meloon
'97 Ski Nautique
'83 SN 2001
peter1234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2011 at 10:21pm
im pretty sure the tin man wasnt too smart ..and if he has gas ..a ticking time bomb....
Jtonor1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jtonor1 Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2011 at 6:19pm
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2011 at 3:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2011 at 1:15pm
Originally posted by tullfooter tullfooter wrote:
Another thought is down draft. You've had some serious winds where you are. If the stack doesn't have a rain/wind cap, wind can blow down the stack and blow out the pilot light. Sounds far fetched, but it happens. My buddy had this happen 5+ times until he had a cap installed. His wife would call me to light the her pilot each time.
You should have a draft diverter on the top of the HWH. Most are built into the tank itself but check.
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2011 at 1:01pm
I just replaced the thermo coupler and it seems to be working well. Thanks again for the help. I'm out of town monday, so this happened at a good time. Cold showers suk.
FWIW-I looked around on the web for some help and found a little, but I'd rather hear from yall. CCF rocks!
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2011 at 11:19am
Petes right about the position also there can be soot deposits built up from flame impingment with the flame too close to the thermo coupling
tullfooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tullfooter Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2011 at 10:39am
Play hard, life's not a trial run.
'85 BFN
'90 BFN
White Lake, Michigan
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2011 at 10:08am
I got bit real bad after I discovered that a thermocouple will stay hot enough to keep the valve open even after the pilot has been out for awhile. I ended up with 2nd dgree burns on my hand. The HWH was leaking water into the burner. I found this out when I relit it and heard the sizzling. I shut it down turned it back on and then made the mistake of going at it with a match. Besides the flames that came out, scalding hot water shot of of the burner as well.
Greg,
The position of the thermocouple in the flame is key as well. The hottest part of the flame is actualy at the very tip where you sometimes can't even see the flame. It's not in the middle where some will place the thermocouple tip.
NEDLUTZ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEDLUTZ Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2011 at 9:29am
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2011 at 1:20am
turn the gas off and be careful!
john
"Loud pipes save lives"
kytom2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kytom2 Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2011 at 11:54pm
Yeppers sounds like what you described is the thermocouple.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2011 at 11:50pm
Thanks guys for the quick replies. I googled thermocouple so I knew for sure what I was looking at. It's screwed to a bracket by the burner and connected to the control box...right? That's what I'm replacing?
Thanks again!
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2011 at 11:27pm
or lousy pilot flame . but odds are thermal coupling. make sure you measure the length before buying one. and its a good time to clean pilot orifice while its down.
hasbeenskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hasbeenskier Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2011 at 11:21pm
More than likely the thermal couple is faulty.
bj
hasbeenskier
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2011 at 9:20pm
If the thermo-couple portion of the gas valve is broken, or not being heated by the flame, then the pilot light will not stay on.... try warming the thermocouple with a match while holding the valve "light" button down.... then light the pilot flame.   could also be a clogged orifice, air in the line, or bad gas valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2011 at 9:10pm
What makes a pilot light not want to stay on? It's on our water heater. I relit it yesterday and it went out after a few hours.
Any help is much appreciated!
1988 BFN-sold
