  New Posts New Posts RSS Feed - Transmission
Transmission
sweet77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sweet77 Quote  Post ReplyReply Direct Link To This Post Topic: Transmission
    Posted: May-15-2011 at 2:58pm
geez was this a commercial truck or what
76 Nautique
"If you do what you always did,You'll get what you always got!"
"An empty wagon makes t
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2011 at 4:17pm
17
Post Options Post Options   Thanks (0) Thanks(0)   Quote sweet77 Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2011 at 10:55am
Here's Your Sign!!!! im guessing about 10 quarts on that one
76 Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2011 at 9:21am
i called Cummins 2 weeks ago and asked how much oil goes into the engine....he got me as i had gave it in the past "to the full mark"
Post Options Post Options   Thanks (0) Thanks(0)   Quote sweet77 Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2011 at 3:13am
Originally posted by Air206 Air206 wrote:
I am with Tim.... ask the folks who put it in as we have seen some variation around here..........
I take it that by the "keep it to yourself" comment in your post, you aren't getting satisfaction from those you've asked so far?
Air206 i havent asked anyone i just found some other post where it seemed like two or more opinions were put out there and im not smart enough to decipher which one works for me. my comment wasnt meant to be rude in any way i just did not want this topic to become a pissing contest i just needed direct answers
I talked to the man with the plan (BOAT DOC) and was told "Sweet, leave the d@#& thang alone " Im learning to listen well. I put the cap back on and moving to the next topic to post about!!!!!!!
76 Nautique
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2011 at 10:19pm
C'mon guys; the hydraulic lines don't match.
1988 BFN-sold
emccallum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote emccallum Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2011 at 3:53pm
If you dont know how to top it off, then how do you know if it is a little low ?
Read the owners manual, as different years have different dipsticks. Manual for your tranny should be in the reference section with pictures of the dipsticks.
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2011 at 2:50pm
Sweet, Do I hear a wagon?    YEP!
Air206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2011 at 2:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2011 at 2:04pm
I wanna say that the boat was at the Docs for a visit so he probably knows and if he doesn't I'd call Chip and just ask .
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2011 at 9:40pm
ATF Dextron III, needs to read full just after shut off.
Probably will mark overfilled if you make a cold reading.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sweet77 Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2011 at 1:13am
My new trans is a little low on fluid. Not knowing what is in there i would like to know the proper way to resolve this problem. I know there are other threads on here but maybe i can get a direct response on this go round
p.s if you are not 100% sure of your response please keep it to yourself
76 Nautique
