  New Posts New Posts RSS Feed - Steering Cable problem?
ScottEvil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottEvil Quote  Post ReplyReply Direct Link To This Post Topic: Steering Cable problem?
    Posted: July-03-2011 at 1:50pm
I have a 1997 Ski Nautique open bow and need to replace the steering cable. Does anyone know the part number from Teleflex that is the correct one? Many choices.
Thanks for the help.
Thanks
ScottEvil
WakeSlayer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2011 at 8:40pm
My cable in my snakeboat is about shot. I need to replace it. Have had one on hand for over a year, just have not got to it. My shakedown run after my strainer seal to impeller issue, told me it got worse...
Mike N
1968 Mustang
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2011 at 4:43pm
My rudder is my next project. This came up recently too, just haven't had time lately.
Mine is one finger operation when the boat is not moving or just idling along forward. As soon as I get on plane the wheel gets pretty stiff. I think it's the additional pressure of the prop wash on the rudder that makes the steering stiffer.
Ladies Love Cool Correct Crafts
eshowcase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eshowcase Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2011 at 4:02pm
I have a '92, not sure on your '93, but mine as a zirk grease fitting on the rudder. Don't just buy a new cable.... I was having the same issue, found that zirk fitting, behind the rear bilge pump, gave it a couple squirts of grease and its like butter now, cost me nothing... did it in 15 minutes.
You can disconnect the cable at the rudder too... check to see if its the rudder that's sticky or the cable. I hate to just buy and replace parts when it might not be the problem. Just sayin'...
Jones View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jones Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2011 at 2:07pm
Originally posted by WakeSlayer WakeSlayer wrote:
Yes, under the dash, behind the steering wheel. It also attaches to the tiller arm on the top of the rudder. Disconnect both, turn the wheel, and rotate the rudder. My guess is they are both fine. When you get the new cable, attach a wire or rope to the old one and remove. Not sure which direction is easiest on your particular boat. I think pull out from the front. This will give you a fish line to pull the new one through. You will have to open your clamp block around the metal tube. To set the new one in place properly, spin your free steering wheel lock to lock, and figure out center, make sure your rudder is centered, and attach, then tighten your clamp block back down.
Also, if you have to remove/replace the helm, remember not to hang it upside down or you will have a pretty embarrassing first outing.
1979 Ski Nautique (sold)
1997 Ski Nautique
1998 Super Sport Nautique
paulcuffe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulcuffe Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2011 at 8:28pm
Thanks man, I appreciate it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2011 at 8:27pm
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulcuffe Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2011 at 8:17pm
The cable is right under the main console right? and after I disconnect, I'd just try to move the rudder?
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2011 at 8:15pm
You need to replace the steering cable. Verify your rudder and helm are ok once you disconnect the cable, but it is going to be the cable.
$200-250 and an hours worth of work.   Very easy repair.
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulcuffe Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2011 at 8:06pm
I have a '93 Ski Nautique and absolutely adore it. I've noticed that it's getting progressively harder to steer each season though. Does anyone have any idea what's wrong? Or what I need to do to fix it? Thanks!
