  New Posts New Posts RSS Feed - FEUL TANK STRAINER
FEUL TANK STRAINER
mylittle83 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mylittle83 Quote  Post ReplyReply Direct Link To This Post Topic: FEUL TANK STRAINER
    Posted: June-21-2011 at 5:11pm
just been replacing parts and want to make sure its rite. does the filter go short end up. and does any one use nautiqueparts.com?
karen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote karen Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2011 at 2:27am
Thanks for the update. I should have read it thoroughly earlier to pellet mill avoid misunderstanding. More interesting post in the future please.http://www.pelletmill.com
jrs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrs Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2011 at 10:50pm
No you do not have any fuel strainer in the tank. You should have a water/fuel serpator filter in line before the fuel pump. Also some early model 83 SN have a screen and filter in the Holley 4160 inlet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mylittle83 Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2011 at 1:02pm
Ya my bad thinking about function i forgot about safty.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2011 at 11:42am
Originally posted by mylittle83 mylittle83 wrote:
that valve is odd why dont cars have them?
Robert, Cars don't have anti siphon valves because they don't have a enclosed bilge where gas could accumulate creating a BIG hazard!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mylittle83 Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2011 at 11:16am
did a flow test and used a fuel pressure gage befor to check something else. was good then. pulled the tank last night and there is a strainer in the top of the pickup tube and a small amount of trash in the tank. that valve is odd why dont cars have them? ill take it to the lake tomarrow. and see how it goes. thanks for the commits, seems the older i get the more i dont like to mess with problems eventhough my wife says i have poject ADD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2011 at 8:58am
Robert,
How's your fuel pump? Use a 5 gal. gas container as a temprary tank and check the pressure you get out of the pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mylittle83 Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2011 at 5:56pm
Acts as though is running out of fuel. will only mantane about 35mph.
everything looks good back to that valve. had it all apart back to the tank last week. blew some air thru it to check the vent ran good for a day. if it dosnt have some kind of sock on it may have something else blocking the tub
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2011 at 4:40pm
Robert,
What problems are you having? Fuel delivery? Check the anti siphon valve at the top of the tank.
Welcome to CCfan. Any pictures? Submit some for the diary section as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mylittle83 Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2011 at 2:42pm
Anyone know if my 83' ski nautique has a strainer on the pick up tube?
