  New Posts New Posts RSS Feed - Trans shaft size
Trans shaft size
rtsuggs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtsuggs Quote  Post ReplyReply Direct Link To This Post Topic: Trans shaft size
    Posted: June-08-2011 at 12:04pm
Yes he does warranty his work but the shaft is pitted. He told me up front it my leak. I just thought someone on here could save me some time and give me the shaft size and seal part number so I could do it all in one day.
Why is it so hard to believe that for $500 you can't get a good job done. He's been building transmissions for 30 yrs and he always give us nautique people a break.
Rob
Thanks
78 nautique
78 ski nautique SOLD
85 ski nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2011 at 10:49am
Originally posted by eric lavine eric lavine wrote:
does he not warranty his work?
On a $500 "rebuild"??? Maybe not!
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2011 at 10:08am
rebuilt also includes re-seal,
picked one up last night Pete, sold the guy a few hundred in parts last year, typical hammer beaton cylinder, all the typical garage rebuild scenario. I would bet when i crack it apart this morning one of the snap rings will be missing...and the obvious, more damage then when he started
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2011 at 4:55pm
Originally posted by Riley Riley wrote:
What should be done on a rebuild?
Bruce,
The clutch pack is the easy one to replace. Almost anyone can do that and this has been proven by some of our members who have been successful. It's when it comes down to the pump when things get more involved and experience like Eric's comes to play. If ALL pump/housing tolerances are not in spec and a couple O rings inside the pump aren't addressed, that's when problems come up. The pump will by pass oil around to it's front side creating pressure where there souldn't be any and push the seal out and or blow oil past it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtsuggs Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2011 at 4:10pm
New clutches and seals and someting else I can't remebet what he said. The pump was ok according to him. Cost $500.
78 nautique
85 ski nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2011 at 11:49am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2011 at 11:46am
Rob,
I have to ask if you went for the $400 rebuild? What did he do to the pump? What did he do - a clutch pack?
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtsuggs Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2011 at 11:38am
Just had it rebuilt this winter. I tried pushing the seal in a little further but it starts leaking again after about 30 min of running. This is the third seal and I'm tired of pulling the trans out. I guess I'll have to pull it out and mic the shaft just thought I could skip a step if someone knew the shaft size and part # for the seal.
Thanks guys
78 nautique
85 ski nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2011 at 9:57am
u can push the seal in an 1/8 farther if the shaft is pitted, i thought the shaft was 1.375   cant remember, but i get the speedi sleeves thru Car Quest
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2011 at 8:39am
Again............. from 2 of your own old threads:
are you sure your pump is in good shape? is it leaking between the shaft and the seal?
Yes, Eric has mentioned it many times, that the seal really doesn't see any pressure if the pump is good. Time for a rebuild???
Rob,
You've been with us over a year and it sounds like you didn't even go to Eric for advice and a quote?? Did you ever put the speedie sleeve in it? Keep in mind, as mentioned in the other thread on your problem that a pitted shaft may not be the only reason for the leak!!!
Send it to the guy that will do it for $400. Maybe he'll do it for less if you tell him not to paint it!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtsuggs Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2011 at 8:41pm
Anyone know the size of the input shaft is on a 78 nautique transmission? I want to order a speedy sleeve before I pull the trans out. It want stop leaking and I'm tired of having seals put in it. Oh and can someone give the part number for the seal and the best place to buy the speedy sleeve?
Thanks Rob
78 nautique
85 ski nautique
