  New Posts New Posts RSS Feed - Southwind Steering Cable
karen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote karen Quote  Post ReplyReply Direct Link To This Post Topic: Southwind Steering Cable
    Posted: June-10-2011 at 2:25am
Thanks for the update. I should have read it thoroughly earlier to pellet mill avoid misunderstanding. More interesting post in the future please.http://www.pelletmill.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-09-2011 at 1:25pm
For $105, just get a new one. You need a 17' cable.
Teleflex steering cables at Go2Marine
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-09-2011 at 1:20pm
Scott,
It sounds like you have fallen for the advertising BS and bought the "cr*p in a can"
Originally posted by Whitfield Whitfield wrote:
At times we also used PB blaster
Hopefully you don't fall for other advertising BS hype like for Fram filters too!
Here's the list of torque requirments copied from the other thread:
Penetrating oil ..... Average load
None ...................... 516 pounds
WD-40 ................... 238 pounds
PB Blaster ............... 214 pounds
Liquid Wrench ......... 127 pounds
Kano Kroil .............. 106 pounds
ATF-Acetone mix.......53 pounds
I don't even consider WD40 to be a penetrating oil so that puts PB at the bottom for me. Kroil is a on line order only so when I was taking my 1927 Flexifour apart and trying to break the rusted pistons loose, I did pick up a can of PB. A week went by with no luck and then the Kroil came in. The next day after using some of the Kroil, all four pistons were loose. I ended up using the PB as a honing lubricant!
The home brew ATF and reducing it with a solvent is real interesting! I need to mix up a batch and give it a try.
Squirtng just the end won't do it. Some have used a lenght of rubber hose clamped off to the other jacket, filled it with a decent penetrating oil and them hooked up the compresed air to force the lube all the way through to the other end. It is successful at times. If not, a new cable is in order.
politicallycorrect View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote politicallycorrect Quote  Post ReplyReply Direct Link To This Post Posted: June-09-2011 at 1:03pm
We've been trying to resurrect our original white steering cable in our southwind 20. Been squirting pb blaster down the cable for a few days now. Any suggestions?
Scott
Skin grows back...fiberglass doesn't!!
