Hard to start, warm after sitting off between sets |
DEF187
Groupie Joined: August-04-2009 Location: Janesville WI Status: Offline Points: 54 |
Posted: May-05-2013 at 10:45am |
Gluvs2brd, yes. It ended up being a timing issue. I had to adjust the timing to 10 degrees BTDC. This fixed the hard to start issue as well as top end speed at WOT. Hope this helps.
Gluvs2brd
Newbie Joined: April-10-2013 Location: Clermont Status: Offline Points: 25 |
Did you ever getmissue resolved? i am having a similiar one,,, thanks
DEF187
Not right away but If you crank it a couple of times it will get slower and slower each time. That's what makes me the most nerves out on the water.
Tim D
After it sits for 15 minutes, does it seem to crank slower?
Tim D
DEF187
This might be hard to explain but I'll try my best. I have an 89 sport with a 351w. It has rebuild carburetor, new heads and valve job, hew exhaust manifolds, new distributor, rotor, points, and fuel filter. Things that are ok but could be replaced; plug wires, PCV valve, mechanical fuel pump, fuel sending unit, blower.
The problem; on first crank the boat starts up with one pump of the throttle. After running for a while and the boat is up to temperature if I sit for more than 15-20 minutes it’s very hard to start, to the point where I have to lift the dog house and remove the flame resistor and spray starter fluid in the carburetor and even sometimes that’s not the key. One thing that I have noticed is that if the boat is off for 5-10 minutes with the blower on I have better luck starting it. After sitting for about 45 minutes it starts good as well. It’s that middle ground that is hard. I couple things that are floating around in my head are, fumes. I usually will turn the blower off if I’m going to sit for that amount of time (15-20) and don’t turn it back on? Possibly it’s not getting enough fresh air? Other things would be to start replacing parts (mentioned above) I wanted to get some opinions first. Anything will help, even a “well duh it’s the blower” comment would be fine, just so that I know! |
