  New Posts New Posts RSS Feed - Speedometers not working
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Topic: Speedometers not working
    Posted: June-24-2011 at 4:48pm
Are these those digital teleflex ones? Could be an entirely different issue.
62 wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 62 wood Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2011 at 10:13pm
Have you tried to gently blow air directly into the back of the speedos to see if the needles move?
Also make sure the tubing running between speedos and pitot dont have a hole or crack in it.
64 American Skier
62 Classic..
73 Ski Nautique
rluniewski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rluniewski Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2011 at 8:49pm
Thanks for the idea but I did disconnect at the dash and at the pitot and was able to blow air thru w/o obstruction. Maybe both gauges went bad at the same time - hard to beleive - the boat is docked and I plan on pulling out the water this weekend so I can take a better look
Swatkinz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swatkinz Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2011 at 6:13pm
Have you tried disconnecting at the dash and at the pitot to see if you can blow air thru w/o obstruction? Perhaps your pitot has trash in it?
Steve
2011 Sport/Air 200
Excalibur 343
2017 Boatmate Tandem Axle Trailer
Former Malibu owner (07, 09)
Post Options Post Options   Thanks (0) Thanks(0)   Quote rluniewski Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2011 at 6:09pm
1999 Sport. Both spedo’s are not working at all. I removed the dash, blew air through the lines and heard some good bubbling at the rear of the boat so I thought I was fine.   Spedo’s still did work so I attempted to push a wire down the rubber hose, maybe made 16 inches on one hose and 20 on the other. The wire is decent gauage (pet fence wire). Any idea??
