  New Posts New Posts RSS Feed - Prop Flop
Prop Flop
SN206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN206 Quote  Post ReplyReply Direct Link To This Post Topic: Prop Flop
    Posted: June-29-2011 at 12:54am
Agreed, I'll be refering to this, this weekend. Thanks.
politicallycorrect View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote politicallycorrect Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2011 at 11:19am
Great thread...this one will be bookmarked for when the boat gets put back together.
Skin grows back...fiberglass doesn't!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2011 at 9:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote politicallycorrect Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2011 at 1:19am
In the process of dismantling the southwind I couldn't get the coupler off of the prop shaft. I decided to pull the prop instead and pull the shaft through the bilge Since the engine is on the floor behind the boat. Once I removed the cotter pin the castle nut was a little more than hand tight. I held on to the prop and smacked the end of the shaft with a dead blow hammer a couple of times and it came right off. Is this an indication of some kind of wear on the prop or shaft? Was it just not tightened correctly? Nothing looks out of whack or wallered out.
