PCM GT40 |
1765MB
Newbie Joined: July-01-2011 Location: Massachusetts Status: Offline Points: 5 |
Posted: July-02-2011 at 4:06pm |
The fuel filter is good, this issue is very consistent at 2600 rpm and seems like the engine goes into a safety mode. I think the advice to check the oil and temp switches is on the right track. Its probably a sender thats gone bad, or something along that line. I won't know for a few days as other events will keep me from foolin around with the boat but I'll post the solution when I get it.
Luchog
did you ever look at the fuel filter?
1765MB
The check engine light did not come on but I will follow your suggestion and reference the service manual to isolate the switches
Thanks |
scottb
Senior Member Joined: July-05-2006 Location: Bolingbrook, IL Status: Offline Points: 376 |
Is the check engine light on? If it will not go above 2500 rmp, then it sounds like it may be in SLOW mode, which means you probably have a problem with your oil pressure switch or temp switch. I think there is a GT-40 service manual in the reference section. The service manual will help you locate the switches. If the problem is caused by one of these switches, you can disconnect one at a time to isolate the problem. Start with the oil pressure switch.
horkn
Sounds like it isn't getting the fuel it needs.
1765MB
I just bought a model year 2001 ski nautique with a PCM GT-40 w/ fuel injection that sat is storage for 1 year. I put a couple of hours on it with no issues. However, last night I took it out and it ran fine until I got to about 2600 rpms and then it bogged down. When I brought it back under 2600 rpms it ran fine again. Any Ideas? By the way the boat has only 70 hours on it and has been professionally maintained.
