  New Posts New Posts RSS Feed - Adjusting twin axle trailer brakes
Alcarlaw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alcarlaw Quote  Post ReplyReply Direct Link To This Post Topic: Adjusting twin axle trailer brakes
    Posted: July-11-2011 at 6:55pm
thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2011 at 8:23pm
"not given"
It's not different. Both a twin and a single work the same and you should do adjust them the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alcarlaw Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2011 at 6:17pm
I am sure I saw somewhere the procedure for setting the brake shoes on a twin axle trailer was slightly different to a single axle. Checking out the Champion trailers site, they suggest adjusting the star nut till you can't move the wheel, then back off 8-10 clicks. If I remember correctly I should back off a different number of clicks for setting up a twin axle. How many, I can't remember... Any help/suggestions appreciated. Thanks
