  New Posts New Posts RSS Feed - Calling Eric - Transmission noise
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Topic: Calling Eric - Transmission noise
    Posted: July-30-2011 at 10:36am
take a pic luch, i need to identify the front and back.
you better keep that boat for a few days and do some shake down runs
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2011 at 2:35pm
Threadjack:
Eric, i'm at the shop and some guys are bringing a brand new Super Air 210 for start up, no fluids in the boat, PCM suggest a fully synthetic mobile 50 oil, wont dexron work there? (for the PCM power vee)
the guy was told to use transmission fluid from the Nautique factory.
update
pulled the dipstick on the unit, it was dexron in it, does it have oone only or is it two separates units as the Indmars?
got to check better as the Mobile 1 stuff as it's not easily available down here
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2011 at 10:01am
get it running good and the noise dhould go away
tomegtt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomegtt Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2011 at 2:49am
Dave,
I'll jump in here on Tom just incase you need to get out on the lake today.
Yes, with a low idle, you can get a dampner plate rattle as well as a reverse planetary gear set rattle.
What Tom is saying about the idle mix screws is if, adjusting them doesn't change anything, then your carb is screwed up. This will produce a rough idle that aggravates the rattle.
microsoft office professional,Office 2007,office 2010,
I really agree with your ideas. Thanks
Salty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Salty Quote  Post ReplyReply Direct Link To This Post Posted: July-27-2011 at 11:30am
Thanks Eric. Understood.
So the noise I am hearing should not suggest any issues other than my timing is off and needs tweaking?
No need to worry about my tranny showing signs of wear or in need of a rebuild as of yet?
I will say it pulls nice. No slipping.   Just that noise ar idle and when put in gear from time to time.
Oh. And it really just started since I dropped in the Pertronics electronic ignition. I need to get the timing light out too!
Salty
2018 GS22 with Z4
2008 Ski Nautique 206 w/Factory Tower, EX343 SOLD
1978 Southwind 18 w/GM305, upgraded 4 barrel intake & carb, all original - vinyl & carpet, etc.
[URL=http://s328.photobucket.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: July-27-2011 at 10:19am
to understand torsionals which disappate with RPMS, at 600 rpms the plug fires with more of a duration between cylinders and are farther apart allowing time for things to bang back and forth, they are created on the powerstroke and in theory imagine a piston slowing coming up towards the sparkplug compressing air, it reaches the top and all of a sudden a stick of dynamite goes off and sends that piston at a higher speed back down towards the bottem....thats what creates torsionals....
a weak springed damper simply aggravates the noise, it doesnt remove the torsionals but it disappates them.
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: July-27-2011 at 12:56am
Originally posted by Salty Salty wrote:
Maybe we can meet up another time?
Sure; I was making sure you saw the other thread.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote Salty Quote  Post ReplyReply Direct Link To This Post Posted: July-27-2011 at 12:37am
Hey Greg. I look forward to meeting you and cant wait to see ur bfn!
I bought a place in Blairsville Ga on Lake Nottely this spring and my boat now sits comfy on a hydrahoist.
Wish I could make it this week end but unfortunately cant.   Guests are coming up.
Salty
2018 GS22 with Z4
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2011 at 10:41pm
Where's your cabin Dave? A few of us are getting together on Lanier this w/e.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote Salty Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2011 at 5:37pm
Ah ha. Thanks Pete.
Will check it out on Friday when I am back up at the Cabin!   I wish I were getting out today!!
Salty
2018 GS22 with Z4
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2011 at 5:25pm
Dave,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Salty Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2011 at 4:29pm
Not sure I fully understand. So u believe the noise is from my engine idle being too low?   What do u mean by if the screws are unresponsive Ive found the problem.
Salty
2018 GS22 with Z4
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2011 at 2:26pm
If the damper is good, then your idle is likely not was smooth as it should be. It doesn't take much.
Adjust your idle mix screws to to get the strongest, smoothest idle while IN GEAR at 600-650 rpm. Playin with them in neutral is marginally productive.
If either screw is unresponsive, you've found your tranny noise.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote Salty Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2011 at 1:02pm
Hi Eric - may be better explained over the phone so let me know if you can take a call.   Everything runs out well however every now and then when I from neutral into forward as I idle out of my cove I hear some rattling noises coming from my tranny.   It goes away if I give it more rpm's.   Doesn't happen all the time - just every now and then.
It happened once down at the SJRR in March and I can't remember who I spoke to about it but they said it is common with these velvet drive transmissions.
I bring it up because it happens a little more frequently now or it may be becuase I am using my boat so much more frequently since it is now permanently on a lift at my new cabin!!!
Please advise oh masterful tranny guy,
Dave
Salty
2018 GS22 with Z4
