  New Posts New Posts RSS Feed - nautique 226
nautique 226
lbutton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lbutton Quote  Post ReplyReply Direct Link To This Post Topic: nautique 226
    Posted: August-04-2011 at 5:35pm
Would never do that Just had the jitters of buying a different boat. When you own a correct craft you only have to upgrade 1 in 20 years!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2011 at 8:41am
Lynn,
Kris is correct. The prop should not be close to the strut. The cutlass bearing is the strut is water lubricated so you ned the room for water flow. Normally it's about one shaft diameter but varies due to slightly different taper depths on every prop.
Hopefully you havent been listening to some MC owner!!
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2011 at 4:07am
are you referring to the space between the front of your prop and the strut?   if you are, then yes, some space is normal :) welcome to ccf!
Post Options Post Options   Thanks (0) Thanks(0)   Quote lbutton Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2011 at 12:56am
I purchased a 2005 226 and noticed after some use that the prop is not flush with the shaft guide. Is this normal or has the shaft shifted from its original position. See photo Any help would be greatly appreciated!
