cutless bearing question |
Posted: August-09-2011 at 12:20pm |
They can be quite sloppy before you need to think about putting in a new rudder port. Try tightening the gland first. If that doesn't remove the slop or some of it, then, do a repack. |
MMT
Groupie Joined: July-12-2010 Location: Northeast IN Status: Offline Points: 74 |
Yes I was speaking of the log. Ok so my next question is at what point do most people change the rudder support as far as wear is concerned?
Kent, No on the rudder port and you only have one in the strut. Where's the "other prop shaft support" you speak of? Are you thinking the log and stuffing box where the shaft goes through the hull? It's not a "support". It's the means of sealing out the water! |
MMT
Do the rudder and both prop shaft supports have cutless bearings in them?
