  New Posts New Posts RSS Feed - Tune up-ignition questions
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Topic: Tune up-ignition questions
    Posted: August-24-2005 at 11:36am
If it starts and runs then the coil is hooked up correctly even if it idles rough. Now you can not go by the notch on the cap to set the firing order. Remove the #1 spark plug and bump the starter until it is on top dead center, you will here air coming from the hole(compression stroke). Now remove the dist cap and look and see where the rotor is pointing and the tower in the cap that matches that position this is where you want to start the firing order from and go clockwise from that point. Check the reference section and there are engine manuals that will list the correct firing order for your make/size engine, you didn't say what engine you have I would assume its a ford 351W but assuming makes an ass out of you and me both, so look in the reference section of this web site and you will find all of the specs for your specific engine.
Nate View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nate Quote  Post ReplyReply Direct Link To This Post Posted: August-23-2005 at 11:34pm
Can someone tell me which side( + - ) of the coil, the wires go to the distributor ? Is the battery side the + side ?
Also, on the distributor cap starting from the notch on the outside of the cap, what is the firing order ?
My engine ran fine until I did a wire,plug, cap, and rotor change. I think I hooked up my coil wrong. Will that effect my ignition resistor?
Any help for a dummy would be great !
