  New Posts New Posts RSS Feed - 64 Skylark
64 Skylark
MartyMabe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartyMabe Quote  Post ReplyReply Direct Link To This Post Topic: 64 Skylark
    Posted: February-13-2012 at 11:25pm
66 Skylark-- rear lifting/tow ring
No Pole- wooden base bucket front seats.
66 Skylark
93 SN
If you're not living in NC, you're just camping out!
turk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote turk Quote  Post ReplyReply Direct Link To This Post Posted: February-12-2012 at 8:52pm
Pete, I have some aluminum seat brackets for newer Nautiques(70's,80's). After reading above information they may not be what your looking for.If it is let me know. Paul.
1982 Ski Nautique
1983 Ski Nautique
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2011 at 8:36pm
Towing / Lifting ring photograph below:
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2011 at 8:18pm
I also have an "Original" pair of aluminum swivel bucket mounts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2011 at 7:51pm
Originally posted by lumiecraft lumiecraft wrote:
I'd like the original for that model aluminum framed bucket seats
Does your Skylark have a front bench or buckets? I assume the latter.
If so, then you should be building wood based seat frames, not looking for aluminum ones. Those werent used until 1969.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2011 at 7:34pm
I have a rear Tow / Lift ring.
Mine was designed for towing recreational skiers and lifting.
But you'll have to inspect your internal mountings to make sure it's still valid for either.
lumiecraft View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lumiecraft Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2011 at 5:42pm
I will keep it as original as possible. Got to get some nice gauges too.
If you don't get it, be patient, you will.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lumiecraft Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2011 at 5:41pm
Actually not after all these years but yes. I think I remember someone, maybe even you, saying they don't exist but have since forgotten. So what about a Center Mount Pull? I guess I can change my AD to reflect that. I had actually found and installed but not connected a Chris Craft Console gear lever to replace the original and a foot throttle and I had even had ready to go a nice old single lever morse shifter and cable assembly ready to go and a Center Pull from an old ChrisCraft Continental that I was going to figure out how to mount. With a center fiberglass bench seat it would have made it much easier but I never mounted that either. The boat was fixed with a new rudder assembly and rudder and a new strut shaft for the old CC. It was an OEM replacement parts. The boat runs well and what I did was sell the boat. Sold it for $2800 and the two kids who purchased it removed the old glass center and built some crappy heavy wood frames for front seating. The parts I included were basically tossed out and never used. They had a fuel tank leak one day and while at the dock proceeded to start the boat and the bilge blew and blew off the fiberglass engine cover into the water. A fire started but they got it out fast. They then put the boat in storage and never touched it again for a few years. I found out and to make a story shorter purchased it back for $500 bucks. Still running very well but needing some wiring replaced and a new tank. Got the wiring replaced and a new poly tank installed. Nice. Way better than original. I can now boat in peace. I still need the parts once again that were removed and tossed. I was actually quite angry because it took me a year and a half or so to source the parts an get the boat fixed in the first place. The boat is undamaged from the small fire. For that I glad. But I still need parts.
I'd like either another fiberglass bench seat and rear matching or the original for that model aluminum framed bucket seats and rear bench. I at least need frame work. I can pay for shipping which will be no problem. I'd like to find another console shifter or another nice old Morse Single lever side shifter. Either will do. I do want and need a center pylon that is ready to mount on the boat and all the proper support hardware as well. Price is not a issue.
Pete :)
Thanks for reminding me that the rear is not a Ski Pull but lift ring only. Got it. I won't forget.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2011 at 5:19pm
as well as an original rear ski pull ring for the rear.
Peter,
You're still looking for that rear deck ski pull after all these years? Once more, they don't exist! The Skylarks had the center pylons if so equipped just like all the other models!! Remember that "thing" a PO replaced the rear lift ring is not a pull. He may have thought it was, but the mounting is not designed for anything except a vertical pull/lift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lumiecraft Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2011 at 11:11pm
Looking for an original set of bucket seats and frames for the front and back of the boat as well as an original rear ski pull ring for the rear. I am also looking for an original foot throttle and dash mounted shifter. Or a good old morse single lever shifter for side mounting. I am also looking for replacement rubber step pads and frames for my boat.
Pete :)
lumiecraft @ gmail . com
I have money. Please send photos and prices of what you have. Zip is 95901 for shipping purposes.
