Stringer Job; leave boat on Trailer?? |
charger496
Senior Member Joined: August-06-2010 Location: atlanta, ga Status: Offline Points: 157 |
Posted: September-08-2011 at 12:17pm |
These hull are so small that distortion is minimal. Mine is also a 2nd gen hull ('77 SN) and I braced the hull while on the trailer. I stripped everything out all at once, too. Some blocks were placed under the transom, the chines, and under the keel at the eye. I could lift the hull into position from each corner (barely!). This also would make it easier for you to move the boat around to spray out the grinding dust. My boat is faster than ever with no handling defects. I wouldn't waste too much time building supports when you could be knee-deep in fiberglass and foam dust!
80SN Barnfind
Senior Member Joined: December-13-2010 Location: Niagara River Status: Offline Points: 122 |
All good info, thanks for the replies. I'll more than likely put the boat on stands and save some room in the garage.
Noel |
Knowledge comes by taking things apart: analysis. But wisdom comes by putting things together.
Big Pappa
Senior Member Joined: March-08-2006 Location: United States Status: Offline Points: 322 |
When I started mine, my floor was pulling away from the sides and by bracing up the boat, while it was on the trailer, in the front of the boat in 2 places then 2 more places in the back it brought the floor back up to the hull so there was not a gap any more.
I do not think it is going to hurt if you do not brace but the hull is going to be a little distorted from it's natural position that it came with from the factory. |
Keeganino
Grand Poobah Joined: October-27-2009 Location: North Carolina Status: Offline Points: 2063 |
Welcome to the website. When I did my Skier I used the trailer as well as some strategically placed supports, and also did one side at a time. With the stringers out and the full weight of the hull on the trailer and no supplemental support, it will bend on around the bunks. As mentioned above the trailer helps spread the load which is ultimately what you are trying to do.
1973 Skier |
KFD14
Senior Member Joined: September-07-2008 Location: Hailey, Idaho Status: Offline Points: 226 |
I think it's important to support the hull, but I think you can use the trailer to help with this. I used some supports either side of the bow with columns under the keel by the drain plug and another just in front of the strut. I also supported the stern on either side just aft of the trailer bunks. I then removed and replaced the stringers one by one. It's a bit tricky to get the weight supported equally but I think the trailer actually helped distribute the load.
I think alot of others have done similar with good results. May not be optimal but it worked for me. |
gun-driver
I don't feel this is a completely true statement. There’s been several done while on the trailer with no reported problems. With that said you do have to properly support it to maintain the shape. |
hasbeenskier
Lift it off the bunks onto stands. Otherwise it will distort the hull.
hasbeenskier
gun-driver
I left my '85 on the trailer and shimmed/supported it where needed. I used the old stringers as patterns and the new fit right in.
I also did one side at a time enabling me to use the existing as a reference and help hold its shape. She runs and tracks great so I guess all is well. |
80SN Barnfind
OK guys, I'm in the "thinking about" stage of doing the stringers on my 80SN and have a question for those that have done it; did you leave the boat on the trailer? Or did you support it by chine and keel? The reason I ask is that I would think that after taking away the structure/backbone of the hull it would have a tendancy to "oil can" over the trailer bunks and take a permanent set once the new stringers are installed and cured.
For those of you that did leave it on the trailer, did you notice any disturbance to the original lines of the hull bottom? If not, I'm assuming Correct Craft put enough glass into the hull and rely on the secondary stringers to simply support the floor. Thanks, Noel |
