  New Posts New Posts RSS Feed - Wiring
Wiring
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Topic: Wiring
    Posted: September-14-2011 at 1:02pm
There's an 87 dash wiring diagram in the reference section:
http://www.correctcraftfan.com/downloads/1987_dash.pdf
Yup, undersized wiring is a common problem. Could be that you're charging just fine, but your dash gauge is telling you differently because the wiring going up there isn't heavy enough.
TheChad1976 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TheChad1976 Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2011 at 5:18pm
Would anyone happen to have a wiring diagram for the charging system of an 87 2001 Ski Nautique?? I am having issues, will not charge over 12 volts, sometimes drops to 10 when runing. I took alternator off to get tested and noticed the wires just seem to be awful thin so I am going to try and replace as I go with a thicker guage. Also having problem with the cables getting hot..
