  New Posts New Posts RSS Feed - real time 911!!!!!!!
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Topic: real time 911!!!!!!!
    Posted: September-19-2011 at 7:29pm
The Perko Flush Pro is designed to take the hose directly, so no need for the bucket. Use one method or the other, not both.
Pete, I have a 1999 Flush pro that still works great.
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2011 at 6:38pm
You may get off with just a burned up impeller. That would probably have been worse if you had the motor get extremely hot, then suddenly have water get to it. You'd have cold water on a very hot engine and that could cause thermo-shock.
Always make sure the engine has "air" cooled itself back to normal before attempting to restart, once you have your water situation sorted out.
MMT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MMT Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2011 at 9:31pm
I hope you weren't using dial up internet?
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2011 at 7:47pm
Considering my screen name I shoulod probably stay out of this but I am trying to get a clearer picture, did you hook the flush system up to a hose in the bucket? I would think it would just draw air from the water intake because that is easier. I would either run a draw hose from the bucket directly off the raw water pump intake if you want to test the pump, or use a pressurised hose with the perko system to run the engine. I mostly use the second option.
1987 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2011 at 7:31pm
Originally posted by MontanaSport MontanaSport wrote:
Would a burned up impeller be my worst case scenario?
Spencer,
You mentioned pressure needed to open the check valve in the Perko. Remember a negative pressure from the RWP sucking will do the same thing. Yes, do check the condition of your impeller.
MontanaSport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MontanaSport Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2011 at 6:43pm
Turn Me Loose, Set Me Free
Post Options Post Options   Thanks (0) Thanks(0)   Quote MontanaSport Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2011 at 6:17pm
I don't think I had enough pressure using the bucket method because the check valve has to have pressure to open.....so it wasn't open, meaning not good running the engine without a water source.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2011 at 6:11pm
The Perko does not have a selector to direct the flow. It's simply a spring loaded check valve system. Lot's of problems with them!!! They usually break in two before you get a chance to use them a couple times. Trash it and use Tim's method.
Spencer,
You mentioned the starter continuing to run. Check the continuity of your start relay. It may be welded together due to a low voltage problem.
jimsport93 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimsport93 Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2011 at 5:59pm
Not familiar with the Perko flush kit. Does it have a selector switch that enables/disables flow from the hose? Just a guess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MontanaSport Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2011 at 5:55pm
I did the 5G bucket thing. Running hose in bucket, charged 10 ft hose to the Perko flush kit. I saw water in there
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimsport93 Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2011 at 5:54pm
How did you hook up the water hose?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MontanaSport Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2011 at 5:52pm
got it turned off.....don't know what was going on but the engine wouldn't turn off even after pulling kill switch, turning off battery switch.........I was about to pull the fuel line but then my wife turned on and off the battery switch again and it killed it.
I think my keypad is starting to take a dump because it sounded like the starter was still engaged and the stop button was not picking up it's switch as I was pushing on it. Did that to me a couple times this summer but it sort of worked itself out....
I didn't notice any water coming out the exhaust when the hose was turned on.   Knowing my luck and my dumba$$ tendencies to mess stuff up, I probably just fried my engine.
It was truly a total freak out moment. No emoticon does my panic attack justice. Temp gauge didn't get above 170 though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimsport93 Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2011 at 5:46pm
Your boat may or may not have one. The lanyard style kill switch is usually a red teather cord connected to a pop up switch located somewhere near the throttle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MontanaSport Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2011 at 5:27pm
where is the emergency kill switch on the 5.8 gt40? I got it running on a flush kit and it won't turn off and I don't see water running out back
PLEASE!!!
