Fuel vent belching gas ??? |
Author | |||
Keeganino
Grand Poobah Joined: October-27-2009 Location: North Carolina Status: Offline Points: 2063 |
Posted: September-22-2011 at 12:30am |
I have this problem too. One more winter project to add to the list. Easy fix too. Right now I try to never fill up much more than 3/4 tank.
1973 Skier |
Hollywood
Just make sure the loop is horizontal, not vertical. You cannot have trap like under your sink, otherwise it will fill with gas or water and no longer vent.
martin 74
Senior Member Joined: January-02-2005 Status: Offline Points: 136 |
High loop the vent hose Get a longer vent hose - like about 5' longer. From the tank make a big loop and strap it to the underside of the aft deck before going to the through hull. Great idea for many of us with vinyl graphics on the transom. I'm doing this ASAP. I never wanted to redo the graphics back there thinking gas leakage would be a reoccurring problem when trailering and backing down the ramp.... Plus it's much safer with less smell. The way gas prices have been fluctuating I have been filling up more when gas is cheaper. A lot of smart folks on this site. Thanks Rich |
BuffaloBFN
Actually, it is pressure. HW's point is to add a second vent for air. |
Hollywood
I didn't read the original post very well. Apparently i've never had my gas tank that full...
Greg, Yes!!!! It worked for me on my Tique. Joel, there's no vertical room between the tank and the deck to get one of the "check valve air/fuel separators" in there. They need to be installed vertically and there just isn't the room. |
BuffaloBFN
That's because the gas sloshes to the back and pushes the fuel up the line. Adding the suggested loop gives the gas farther to travel without spilling out. |
MMT
Groupie Joined: July-12-2010 Location: Northeast IN Status: Offline Points: 74 |
Its not from pressure building up, it is when i am accelerating. |
Eric, If I was taking his meds, I wouldn't be able to write at all!! |
M3Fan
How about adding a fuel/air separator?
Hollywood
When it's happening crack open the fill cap, it will stop the siphon/belching.
eric lavine
I thought for a minute 79 was filling in for you Pete
MMT
I follow. Lol. Thanks pete i will give that a try.
eric lavine
Pete, double up on the meds, you've been edgy lately
Kent isn't following the idea!! Kent, High loop the vent hose!! It works!!! Do you want a picture?? Get a longer vent hose - like about 5' longer. From the tank make a big loop and strap it to the underside of the aft deck before going to the through hull. BTW, not overfilling the tank helps too! |
sweet77
Gold Member Joined: January-06-2011 Location: Florida Status: Offline Points: 666 |
i just don't fill my boat completely up. i filled up one night and the next day my house and garage smelled like gas. it was horrible so i siphoned the excess fuel out never had anymore trouble
Luchog
I'm not sure I follow your idea.
And then I though on the one way valve i suggested earlier, that would work for not letting water in, not fuel out, so dischard that idea. |
MMT
I can't really high loop it. The glass is directly above it now. I was wondering if I could find some sort of petroleum resistant foam to pack in the hose, in a spot where it couldn't get back into the tank.
Luchog
Mine does the same thing, ---wrong idea/bad suggestion edited for future readers----
add a high loop on the hose to the vent |
MMT
I bought my Tique in pieces 81 Tique and finally got it in the water about a month ago. Absolutely no issues at all, except that when it's full of gas the vent belches gas out on the back of the hull into the lake.
Is there supposed to be some sort of baffle or valve in the vent hose to prevent this from happening? Thanks, Kent |
