  New Posts New Posts RSS Feed - 86 sn rudder
86 sn rudder
lakedog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lakedog55 Quote  Post ReplyReply Direct Link To This Post Topic: 86 sn rudder
    Posted: September-20-2011 at 12:09am
Thanks,
I put 4 3/16 rings of the gortex, it seems to loose to me rudder turns with no pressure at all and has about a 1/16 of slop, I will try tightening some more but it is pretty tight. On another subject the ARE shaft does not come with a slip ring is it not needed. I am not sure what it is really called but it when around the other shaft and tightened with a set. One more the new props seem so thin I was worried about the reinstallation using the old board trick, Would it be better to use two people on the ARE and get both nuts tight at once.
Mike
Lakedog55
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2011 at 11:01pm
Mike,
Just "cram the rings in there!! The more the better but do leave yourself some room for adjustment. Don't worry about getting it to tight as mentioned earlier - the rudder port is not constantly rotating!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote lakedog55 Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2011 at 9:12pm
Going to reinstall rudder and repack. Man I need a tutorial. I took it apart 9 months ago and am a little turned around on zeroing out the steering and which way is the best for reinstall. I was also able to get a machine shop to straighten rudder. Existing packing had 5 rings in it I can remember my 83 taking that many.?
Thanks Mike
Lakedog55
