impeller type? |
woodyelc
Senior Member Joined: February-17-2004 Location: orlando Status: Offline Points: 378 |
Posted: November-05-2005 at 12:16pm |
LATE REPLY. YOUR ENGINE IS OMC WHICH USED ITS OWN KIND OF WATER PUMP. A SHERWOOD IMPELLER WILL NOT FIT INTO THE HOUSING. SOMEBODY MIGHT HAVE CHANGED THE PUMP TO A SHERWOOD. IF YOU WOULD CALL ME AT 407-851-1965. I WILL TRY TO HELP YOU. I DO NOT KNOW WHO YOU TALKED TO AT CORRECT CRAFT. THAT IMPELLER IS STOCK ITEM AT THIS PLACE. HOPE I WAS ABLE TO HELP.
woodyelc
southwind 20
Newbie Joined: August-08-2005 Location: United States Status: Offline Points: 30 |
Stang...
Sorry I took so loing to get back...puter problems. I live in Washburn about 25 miles from Peoria. I usually put the boat in at Lacon. |
Git One ON!
stang72
Good to hear the problem is solved!BTW...do you hang your hat in Peoria?
southwind 20
Thanks for the advice. Vince was great and did alot of research to find the proper impeller. Seems that year (76) Sherwood used the H-85, G-42-2. and the G-46. All took the same impeller and he was able to locate 2 of them. Thanks to stang and Vince at skidim. You guys make boat work a little less painful!
Git One ON!
stang72
Call and ask for Vince at Skidim...he will tell you what you need!Link is on the site!
southwind 20
I have a 1976 Southwind 20 and I need an impeller. I contacted Correct Craft in Fla. and they said they needed to know the brand of impeller. I am not sure as the housings are not stamped with a maker. It has an OMC GM 250hp 350 emgine with RH rotation. The pump is pulley driven and sits to the lower left of the engine when facing it. The impeller has 6 vanes and has the number
J-7480 on the inside and also the lettering LORD. Any help would be appreciated. Thanks! |
Git One ON!
