  New Posts New Posts RSS Feed - Wanted: Trailer for 1997 Sport Nautique
WAKE-up View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WAKE-up Quote  Post ReplyReply Direct Link To This Post Topic: Wanted: Trailer for 1997 Sport Nautique
    Posted: October-04-2011 at 12:42am
charles
the good thing is that you now have your boat, as for the fit it may be a trailer for a different model as the sport is wider and longer than ski getting to axle under motor typically could be adjusted from several mfg the wheel well issue may be more involved to adapt
it is probably going to be harder to find a trailer as most well built trailers stick around for the life of the boat. you may also have to travel some miles though following this site i'm guessing if you can find the trailer you could also find someone here to check it out for you first
paul
cgofort View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cgofort Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2011 at 1:31am
Well, I was able to pick up my boat, but there are some serious issues with the trailer.
I already replaced the tires and wheels, repacked bearings, and rewired the lights just to get the trailer road -worthy.     When I got the boat on, I find the fit just isn't right.The fenders rub on the sides of the boat, and there is NO tongue weight.
Does anyone know where i can get a used one or do you have to buy a new one?
Thanks,
Charles
Post Options Post Options   Thanks (0) Thanks(0)   Quote cgofort Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2011 at 1:26pm
I just purchased a sport nautique, ad said comes with trailer, however the trailer has sat in a field for years, looks terrible. I'm at a position where it may cost more to repair than to purchase a used one. Any ideas where one could be found in the Austin area?
Much thanks!
