  New Posts New Posts RSS Feed - New Starter grinding
SMay81SN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SMay81SN Quote  Post ReplyReply Direct Link To This Post Topic: New Starter grinding
    Posted: September-08-2005 at 8:16pm
I don't believe I was complaining. Maybe you ought to stop being such an ass. You probably don’t even have a Nautique and are just jealous of all of us on this site that do.
Scott
Our 94 SN
Pinto Bean View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pinto Bean Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2005 at 7:19pm
You have a cheap starter. Get a new one and stop complaining.
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: September-06-2005 at 12:40pm
If what you did got you skiing, then what you did was 100% spot on. Get that starter exchanged pronto as the failure scenario will reoccur with possibly more dire results.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SMay81SN Quote  Post ReplyReply Direct Link To This Post Posted: September-06-2005 at 3:05am
Starter on my 81SN is new this past May. This weekend I had a strange thing happen. Went to start after running it all day. Sounded like it was grinding, of course I stopped, tried again, same thing. Told the kids go do some thing for an hour I will be working on the boat for a while. Disconnected the battery, took starter off and pulled it out. I found a 1 inch bushing inside the bell housing. I looked at the starter and the spindle that the gear slides up and down on was tilted. I figured the bushing went in side the end of the starter and the spindle went inside it. Did that, found what I thought was a compression ring and pounded that in the end of the starter. Put the starter back in hooked up the battery and cranked first time, no grinding and worked the rest of the weekend. We were back skiing, wakeboarding and tubing in 45 minutes. I don’t know what I did was right but it worked.
Does anyone know what might have happen to the started and should I see about exchanging it for a new one since its only 5-6 months old?
Scott
Our 94 SN
