Putting boat in gear |
Posted: November-06-2011 at 8:57pm |
Brian,
Take some time when you get a chance and look at the Velvet drive manual in the ref section. I feel you will get a better understanding on how theses things really work. |
Bri892001
I agree with the above. I'd also check your tranny fluid level too.
I don't know much about transmissions, but these are ultimately shifted hydraulically, right? Is the tranny pump powered by the engine, whether or not it is in gear? It's almost like he's having to get fluid moving before it will do anything. Reminds me of a car engine that's low on coolant, and you have to rev it a bit to get enough moving to get heat. |
marmon77
Senior Member Joined: August-01-2010 Location: Dade City, Fl. Status: Offline Points: 112 |
Thanks guys will work on it tomorrow!
Morfoot
Here's the link to a thread from a few years back and how to "rig" your throttle cable.
Throttle rigging |
BuffaloBFN
Disconnect your cable at the tranny and try it manually. If it works that way, you only need to adjust the cable.
marmon77
Tried the search, didn't come up with anything. Searched: shift cable adjustment,adjusting shift cable, adjusting transmission cable,transmission cable adjustment, cable adjustment. If you have a specific thread I would be happy to read it. Thanks
marmon77
No I haven't I'll try the search
It sounds like your shift and throttle cables need adjusting. There are a couple of real good threads on how to do it. Have you tried any adjusting?
marmon77
Between 6-700 RPM's. I have to rev it real quick to around 1000 then pull back real quick so it doesn't "hit" hard when it goes in gear. If that helps you.
behindpropeller
What is your current idle RPM? You can turn up the idle RPM but if your idle RPM is already correct then just turning the idle rpm up without fixing the other problem will just lead to excess wear on your tranny. |
marmon77
On my "88" SN-2001, when I go to put it in gear I have to do a quick rev-up with the throtle then back to almost neutral before it will shift. In other words the RPM's have to be up kinda high before it will shift but once it's in gear there's not a problem. Is there something that needs to be adjusted to correct this? Thanks
