  New Posts New Posts RSS Feed - erratic idle
erratic idle
skyhawkflyer View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote skyhawkflyer Quote  Post ReplyReply Direct Link To This Post Topic: erratic idle
    Posted: September-19-2005 at 7:55pm
When you accelerate your no longer on the idle circuit. Good luck with the rebuild.
Bob's2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob's2001 Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2005 at 3:49pm
Check at the base of the carb. Mine was acting the same way and it had a vacuum leak between the carb & manifold.
Bob Ed
83 2001
88skisupreme View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 88skisupreme Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2005 at 1:51pm
I dont think its the power valve, it takes off just fine everytime even pulling wakeboarders up, only problem is at idle. I'm thinking its carb rebuild time.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote skyhawkflyer Quote  Post ReplyReply Direct Link To This Post Posted: September-14-2005 at 8:11pm
If it's a holley a popped power valve will do just that. Fuel leaking through will affect the idle circuit and wreak havock with the forward float, causing the surge. Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote 88skisupreme Quote  Post ReplyReply Direct Link To This Post Posted: September-12-2005 at 6:12pm
will check thanks for the advice, also forgot to mention it only does this once its warmed up.
jameski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameski Quote  Post ReplyReply Direct Link To This Post Posted: September-12-2005 at 5:57pm
Also check the mechanical advance springs in your distributor.
current boat
94 Sport Nautique
previous boat
78 Martinique
marks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marks Quote  Post ReplyReply Direct Link To This Post Posted: September-12-2005 at 4:51pm
It does sound like a carb problem, but before you do the rebuild, do a tune-up on the engine and make sure to check the timing. When I bought my boat, the idle was inconsistent. I found the root cause was the timing being off by 10 degrees.
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: September-12-2005 at 3:04pm
It is probably carb related. I concur with 79. Rebuilding the carb will probably reveal the problem.
79nautique View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2005 at 6:10am
rebuild the carb, or you haven't located the vaccum leak yet
Post Options Post Options   Thanks (0) Thanks(0)   Quote 88skisupreme Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2005 at 8:54pm
Friend's boat has a weird idle, it revs up and down. Ocassionally dies but usually just keeps running with the idle like that. Runs fine at crusing speed. Sometimes the idle straightens out for a few second and then goes back to the reving up and down.
checked for vaccum leaks, pcv valve replaced, any more ideas? Carb related maybe?
