can anyone identify this pylon? |
Author | ||
sams 85
Senior Member Joined: September-28-2011 Location: nc Status: Offline Points: 120 |
Posted: February-25-2012 at 10:40am |
well i will be mixing up some atf/acetone today- i'll let you know how it works.
Throw a 4x4 or 6x6 across several bottom truss cords to spread the load. Get yourself some decent penetrating oil like Kroil or mix up 50% acetone and 50% ATF. Throw the WD40 and PB in the trash. You have fallen for marketing "hype".
You better not then,I have an 8" steel beam and can pull motors with it. It actually was lifting the boat and unloading the trailer springs,I just wanted to let you know the forces involved.
sams 85
allrighty, well i don't know if my 2x4 will take the weight-but i may give that a go
Steve I had mine out 20 yrs ago to paint it silver because my buddies 77 had the aluminium one.Decided a couple of years ago that I wanted to paint it white again could not get it out.I ended up hooking a nylon strap on to it and pulling it out with a come-a-long hooked to the overhead beam in my garage,it was tough.
sams 85
ok, so sorry to ask this here, but i need some help with my pylon and you guys have yours out so thats why i'm asking in this thread...
i would like any tips and tricks for getting my pylon out!!! mine is a cold bitch- i have the bottom pin out, acutally both bottom pins out. its still not budging. i have tried putting wd40, pb blaster, a pry bar (very carefully i may add) and nothing seems to budge it. just looking for some ideas here. thanks! |
Infinite5ths
Groupie Joined: August-12-2011 Location: Cary, NC Status: Offline Points: 74 |
john b
Grand Poobah Joined: July-06-2011 Location: lake Sweeny Status: Offline Points: 3241 |
I am reasonably certain that if I were to hit a big wave the pylon would pierce the hull and come to rest somewhere in the earth's mantle.
1970 Mustang "Theseus' paradox"
If everyone else is doing it, you're too late! |
Infinite5ths
Somebody PLEASE tell me that was a typo. I'm sitting here imagining a pylon that weighs more than the engine/tranny in my 176. |
M3Fan
That's what she said?
Sorry. |
I have seen them both in person and agree with Tim,meaning the steel one is identical to mine,and the 69 did not leave Florida with the other one in it
John, that is an original Correct Craft pylon, but it would NOT be original to your '69 Mustang. That particular model was used very briefly- roughly '74-75. It shares the same ring and finger with the later (2.5" diameter) pylons, used '76-87. The OD is quite a bit smaller though. I believe the earlier pylons were also a different material- probably steel? For comparison's sake, here is the pylon in Bruce's '74 Skier: Here is the best picture I have of the earlier pylon- you should be able to see the differences. Through ~1970, it seems most were straight (my Sister's Mustang is), but Ive seen a few that had a bend just above the floor. I *think* most '71-73 pylons have that bend, like this one- note the rearward angle. It sounds like the heavier pylon youre describing that came with your '70 is probably the original. |
john b
Thanks for sharing your knowledge Pete.
The 70 Mustang came with a steel pylon that weighs about 832 pounds and has a slightly smaller diameter. It is painted white and has a smaller ring. The PO says it is original to the 70 Mustang. He fabricated a pylon about 1' longer than the original and installed it because he was a boarder. The 69 came with this aluminum pylon and no one seems to know if its original. I have the floor trim ring, but it is up in Manni Waters so I can't try it to see if it fits the larger diameter aluminum one. |
ny_nautique
Platinum Member Joined: June-01-2011 Location: Albany NY Status: Offline Points: 1215 |
Looks to me like it's from a Southern Hemisphere boat. Ask one of the guys from Argentina or Australia
- Jeff
1999 Ski Nautique |
John,
That pylon may be the original. In 69 they simply went trhough a reinforced hole in the floor to the keel socket in the bilge. Many were dealer installed. I installed several in CC's back in those days working at a CC dealership. |
john b
This pylon came in my 69 Mustang and I do not know what it is originally from.
