  New Posts New Posts RSS Feed - Stringers - Doug Fir or LVL?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Topic: Stringers - Doug Fir or LVL?
    Posted: February-20-2012 at 5:51pm
Found it and always thought it was a good way to avoid the problems of threading into wood
juniorwoody View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorwoody Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2012 at 5:17pm
I think the LVL will be just fine. Resins and adhesives in the waterproof category have come a long way in my days. I do tend to have an inherent distrust of them which may be unsanctioned. As for our progress on the 1950 Utility, Pete, the hull materials are partially removed and there have been many interruptions. There needs to be some plywood repairs and this represents my next challenge. Will pick up the thread as soon as I return from FL and get into gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2012 at 1:58pm
Jack,
Eric has mentioned a method he has used whenthe stringer strength in in question or when you use a composite. He will drill a horizontal hole in the stringer. Then in the hole insert a piece of round stock steel with a drilled and tapped hole in it. Then from the top run a bolt down into it. Unless very carefully done, this really opens up the stringer to potential water.
In the 40+ years I've been around wood boats, I have never seen a stringer split from a lag bolt.
How's your project going?
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorwoody Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2012 at 12:55pm
No intention of debating the proper preparation of the hole prior to installation just pointing out a possible weak spot even with the correct piloting. I am curious as to the solution Eric points out though Pete.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2012 at 12:30pm
Eric has posted a real nice,imo,way to solve that problem but I can't find it.Maybe he can repost it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2012 at 12:27pm
Originally posted by juniorwoody juniorwoody wrote:
Trying to remain open minded here and with all due respects to everyone's good intentions, my only real concern with the laminated beam (laminated veneer lumber)would be where the bolts enter between the veneers. Will the glue prevent a separation of the veneers? In most other respects the LVL may be superior to fir, weight not withstanding. Time shall be the only true test of the bolt holding characteristics.
Peter,
I believe I was the one way back who recommended the LVL as an alternate if Doug Fir wasn't available. It's an "engineered" product so it's very consistent in strength. All the grain runs the length of the LVL and with the addition of the glue, makes it stronger that a solid. You can look at the charts and see an LVL will carry more load than a solid. It however must be sealed with a decent CPES treatment and of course an epoxy layup. Lagging engine mounts to it is not an issue since the grain is running the proper direction but, after drilling the pilot holes for the lags, they must be CPES'd and then sealed with 5200.
You can split a solid open too if the proper pilot and clearance hole aren't drilled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorwoody Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2012 at 12:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2012 at 5:30pm
Originally posted by OverMyHead OverMyHead wrote:
What is the weight difference between LVL and fir? seems about double at a construction site.
Dave,
You may be lifting Hem Fir and then the LVL which is Doug Fir! Hem is lighter. The only additional weight in a LVL is the glue. It's not much. Also, don't forget the LVL is 1/4" thicker than 2x stock. They were smart in doing that since it eliminates the 1/2" piece of ply between the typical "stick" made header.
Big Pappa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2012 at 5:14pm
I have not seen a weight on a new Fir stringer, but my LVL stringer after being cut out and still in bare wood weighed 27 pounds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2012 at 5:08pm
Originally posted by Cuda Chris Cuda Chris wrote:
Big Pappa,
I think I am going to head down the LVL path. The structural characteristics of LVL products are superior to solid timbers and more dimensionally stable.
What brand of resin did you use for your project? West systems is very pricey and I have to believe there is someone out there making the same stuff and a slightly lower price point.
Cheers
I ordered all of my glass, foam and resin from US Composites, even with shipping included it was the best price I could find on epoxy.
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2012 at 4:13pm
1987 Ski Nautique
Cuda Chris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cuda Chris Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2012 at 4:08pm
Big Pappa,
Cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2012 at 4:29pm
Originally posted by bbishop1974 bbishop1974 wrote:
kris[big papa],thanks for your great documentation.its definitly a hard choice and your a pioneer.you have to give us a review when done
Will do!!
bbishop1974 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bbishop1974 Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2012 at 11:17am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Posted: February-15-2012 at 2:00am
I am using LVL in my build and I think it is going to work great. I was wondering about the same thing bbishop1974 so I took a piece of the scrap LVL and put it in my driveway directly under one of my downspouts. It has been sitting there for over a year now and it is still solid. I know it has had time to dry out as well but it has been sitting outside every day the whole time. It is discolored but still as strong as the day I put it out there as far as I can tell.
With the LVL CPESed and covered in multiple layers Epoxy and glass I think it will be just as good and last just as long as Doug Fir.
If you have not found it yet you can see my stringer thread in my signature.
Kris
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cuda Chris Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2012 at 9:58pm
I have not yet made a decision on fir vs lvl. I prefer the stability of the lvl over fir. Called a few places around town and can not locate clear fir, lvl's are easily accessible and less expensive tan fir. I imagine a healthy treatment of cpes will be required.
Thanks for the input and I'll be posting pics soon!
1968 Barracuda Super Sport
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2012 at 11:10am
If you use CPES and epoxy (recommended), then I would not worry about water on ether the solid Fir or LVL. Just make sure that any holes drilled into the stringer system after layup get CPES'd and then 5200'd. (engine mount lags) If you go no foam and use ply for the sole, then it should be bonded with thickened epoxy and no screws.
65 'cuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 65 'cuda Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2012 at 10:45am
Use the fir!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cuda Chris Quote  Post ReplyReply Direct Link To This Post Posted: February-05-2012 at 6:41pm
I came across this system on Jamestown Distributors and would be interested if anyone has installed something like it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cuda Chris Quote  Post ReplyReply Direct Link To This Post Posted: February-05-2012 at 6:34pm
Thanks for the tip. I will most likely replace everything the way it came from the factory. At some point I'll need to post some photos of my project.
Thanks for the input!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bbishop1974 Quote  Post ReplyReply Direct Link To This Post Posted: February-05-2012 at 6:02pm
cuda,its a difficult choice.for me the deciding factor was upon disassembly,everything was very wet.anything that was made out of ply was mush,doug fir peices were pretty decent considering how wet they were.my concearn was if the lvl were to get wet the rot would take hold quickly.i realize their are several factors to consider here,just my 2 cents
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cuda Chris Quote  Post ReplyReply Direct Link To This Post Posted: February-05-2012 at 5:46pm
Great thanks, ill look into it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-05-2012 at 5:44pm
Chris,
There is a thread on a LVL stringer job when the member could not find the Doug Fir in his area. It looked to me that it turned out fantastic. Just watch out for the thickness difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cuda Chris Quote  Post ReplyReply Direct Link To This Post Posted: February-05-2012 at 5:30pm
Can anyone weigh in on this? I removed the last bit of foam from my boat yesterday and am getting ready to do the stringers. I have been thinking of using LVL's instead of the doug fir.
