3" Exhaust Hose $8/ft |
Waterdog
Posted: February-13-2012 at 12:59pm |
What happened to using copper / stainless 3 in tubing in place of the mufflers?
I like the idea of using the corrugated rubber all the way back. Less joints to leak and maybe a lower exhaust tone. I have to open up the 86 in the next day or so. I’ll measure the length from the riser to the transom and post it here. |
oledb4
Senior Member Joined: December-06-2011 Location: Orlando, FL Status: Offline Points: 122 |
Pete,
I should have worded that differently. As you stated, the link worked, but his post no longer exists. If someone has his info I was going to try to contact him. |
Justin, The link worked for me but it does come up that the seller has removed the listing. Maybe he sold all of the hose? |
oledb4
does anyone have this guys information? the link in the original post doesnt work
KFD14
Senior Member Joined: September-07-2008 Location: Hailey, Idaho Status: Offline Points: 226 |
Ya, I guess that's a good idea, thanks.
I know that 7' per side was more than enough for our '79 BFN (454 with short risers). I took the chance and ordered 2 lengths of 6' for our '80 Ski Nautique (351w with long risers). If no one can provide an exact measurement, a call to White Lake or Woody may confirm how much you need.
KFD14
Great now that we got that sorted out anyone know how much I need from riser to outlet on an 83 SN, mine is in storage for the winter. I was thinking of elliminating the mufflers and my hose is showing it's age. Was thinking of going with stainless but this is such a good deal it's hard to pass up.
Corrugated is smooth on the inside, so it works great for everything.
Bri892001
A separate but related question:
Is there any advantage to using smooth wall, whether re-enforced or not, as far as flow characteristics? Or is it pretty negligible? I realize you have to use corrugated to make bends, but just wondering it's better to use smooth wall for the straight runs? |
Noel is right! The seller didnt know what he had... he sent me a picture and confirmed that it is in fact corrugated.
80SN Barnfind
Senior Member Joined: December-13-2010 Location: Niagara River Status: Offline Points: 122 |
If I knew I had to prove my ability to discern corrugated hose from smooth wall hose I would have posted this in the first place
Knowledge comes by taking things apart: analysis. But wisdom comes by putting things together.
I am 99% certain that the stuff for sale is corrugated based on Noel's input... but since the seller offered to send me some close up pictures this evening, I am waiting to see them before pulling the trigger. I will report back with what I find!
KFD14
Did you guys get this figured out, I need some as well.
MartyMabe
Grand Poobah Joined: February-21-2006 Location: High Point,NC Status: Offline Points: 3980 |
Take a pic. It didn't happen if ya don't have the pic
Thanks for the confirmation!
80SN Barnfind
As sure as Correct Craft foam soaks up water!!
What's sitting in my basement right now is the corrugated pictured above. |
This guy is certain that he doesnt have corrugated hose. Just to make sure we are on the same page, here is what corrugated looks like:
Hardwall (wire reinforced) and Softwall (not wire reinforced) are also available out there. Both appear smooth on the outside, like this: Obviously, Hardwall and Corrugated are not the same, though both are wire reinforced. Corrugated is much better at sharp bends. Youre sure you received corrugated? This guy says he only had 1 roll and sent you the same stuff. Somebody's confused! (Right now, its me!) |
Weird... seems he either has 2 different types of hose, or doesnt know what he's selling!
80SN Barnfind
Definitely corrugated
Did you get the hose yet? I just traded emails with the guy and he said its not corrugated hose- only wire reinforced. That isnt what I would use for the large bends coming off the manifolds- I prefer the corrugated. The part number he lists cross referenced to a corrugated hose on one site though... maybe he was wrong?
Hmmm, that length is interesting- I thought the mufflers were close to 48". |
80SN Barnfind
Off the elbow to the muffler is around 3-1/2ft & muffler to thru hull is 14". I had him cut 2 pieces @5ft each.
Noel |
Wow, thats a great price- nice find. Do you recall exactly how much you needed per side on your '80? Im thinking each run is ~6'... sound about right?
80SN Barnfind
Found this on Craigs Rochester NY. 3" Exhaust Hose
I bought enough for my 80SN resto, great price and he cut and shipped. Noel |
