Checking manifolds |
David F ![]() Platinum Member ![]() Joined: June-11-2004 Location: United States Status: Offline Points: 1770 |
![]() ![]() ![]() ![]() ![]() Posted: September-22-2005 at 1:04pm |
I should have mentioned that I highly recommend that you follow my proceedure with the manifolds removed. You hate getting water into the engine if the blank of plate leaks while testing.
photoshop ![]() Newbie ![]() Joined: September-15-2005 Location: United States Status: Offline Points: 25 |
Yes it is the exhaust manifolds.Thanks for your help.
Photoshop
I assume you are speaking of the exhaust manifolds. You can pressure test them. Bolt a solid rubber (thick) sheet between the manifold and riser to block of the water passages. you could also use sheet metal with gasket material on both sides. Then cobble together a fitting for the drain plug that will allow you to connect your garden hose to the manifold. Turn on the water and look for leaking water at the manifold.
Is there anyay to test them?I have an old set and wonder if they are cracked or not.
Thanks Photoshop |
Photoshop
