Chirpping sound near tranny |
stang72
Posted: October-18-2005 at 11:00pm |
Jeff Kostis...you were right on...the prop nut was a tad loose....snugged it up and sound was gone! Interesting how some things that elude a person can be so simple...thanks for directing my attention to the prop!!!
JoelH
Guest |
What year is the boat? Early PCM PP trannies made this noise and there is a fix for it....
JEFF KOSTIS
Thats what I love about this site! We can share info on similar problems and hopefully win a few times. I hope it cures yours!
stang72
Jeff ...thanks for that info. I have another prop. reconditioned and balanced! Easy enough to find out!!!
I would never have thought of that. |
JEFF KOSTIS
If the stuffing box is cool, youre probably all set there. That noise youre describing is the same as what I had on mine. It sounded like a squeek that needed a shot of oil. After playing around and around, it ended up being the prop. It was slightly out of whack(didnt vibrate) and would resonate the shaft. It was the weirdest thing ever. If someone told me that, I would of told them "yeah right". My neighbors Ski Centurion had the similar type of noise and he thought he was gonna have to pull the tranny. I told him what happened with mine and he didnt have a spare prop, so ended up buying the exact OEM replacement that was currently on the boat. He Swapped it out, and no noise all summer!!
HOLESHOT
Groupie Joined: July-08-2005 Location: United States Status: Offline Points: 47 |
stang i have the same sound comimg from my shaft too . i have checked the pack nut and it seems to be ok. i am going to change the strut bushing to see if that cures it .
i'll let you know if it does |
IF IT HAS A SPARKPLUG I CAN FIX IT
stang72
Last week I started hearing a chirpping sound coming from the rear of the boat...when going from idle to forward idle.was'nt happening with any consistancy? More present when I had a skier in the water(drag from the skier).
It sounded more like a rubber squeak...thats the beat I can describe it. If the stuffing box is too tight...could it sound that way? Perhaps the bushing in the strut? Nothing has happened that would cause the shaft to change alienment position... Got any suggestions what to look for? Thanks! |
