Winterizing |
bkhallpass
Posted: September-27-2005 at 7:44pm |
See your point. It is rare that we go more than a couple of weeks without using the boat, and if we do, I usually drop it off the lift and run it for 10 or 15 minutes just to keep it cleaned out and to keep the batteries fresh. We have had 2 or 3 freeze episodes in the last 10 years. If that happens, I either
pull it out and into the garage, or put a light on the motor. BKH |
Livin' the Dream
David F
I agree with Tim. If the boat is in warmer climates BUT is not going to be used during the winter then the antifreeze is more for rust/scale protection than freeze protection.
If the block is full of water, then the scale is usually not much of an issue. It is when the water is drained and cast iron is allowed to oxidize more deeply since it is exposed to more oxygen. I could be all wet on this, just what I believe and see from year to year. |
Tim D
I don't care where you live, I wouldn't leave lake water or tap water in a cast iron block and/or heads all winter. You need to let it sit for a about a month, hook up the fake a lake and when the thermostat opens, you'll see how much rust can come out. I put antifreeze in the motor for freezing, and rust protection. Oh, when I mentioned cranking the boat above, if it fires up I only let it run maybe 5 seconds. I don't hook any water up. I take the raw pump belt off so the impellor will not melt. And don't forget to take the hose off the raw pump and blow the water out the transmission cooler.
Tim D
mackwrench
Senior Member Joined: February-25-2005 Location: Gone Status: Offline Points: 190 |
I have draincocks on block, exhaust, & trans cooler, and have used the drop light deal sometimes.
NO LONGER A MEMBER
79nautique
Guest |
must be nice not having to do much to winterize, but I have a suggestion for you guy's. Do any of you have the drain kit instailed on you engines? I was talking to Vince @ SKIDIM and he told me all he does is drain the water out of the block if it's going to get below 45 degrees. I have it on mine and it takes about thirty seconds to open them up
Bhedbloom
Senior Member Joined: December-01-2004 Location: United States Status: Offline Points: 116 |
I know this may be over the top and too much rigging for some, but I like to use my boats all year around in South Carolina. I run a drop cord to my boats with two 60W light bulbs mounted under the engine cover. The bulbs are mounted in a clamp type fixture w/ a protective bezzle to keep them from touching anything in the engine compartment. I also purchased a digital outdoor temp. sensor unit from Best Buy and leave it in the engine compartment during the winter. I can sit at my desk and monitor what the temp is inside the boat. Last year when the outdoor temp dipped to 17 degrees the engine was a toasty 48 degrees.
Only negative is power loss. I have not had to fire up the generator yet, but I know I will one of these years. Happy Boating All Year Around !!! |
Barry, South Carolina
bkhallpass
Mack, I'm with you man. We have a two step winterization here in CA. 1) remove the bimini top and put it in the garage, and 2) put the wetsuits in the boat. BKH |
Livin' the Dream
mackwrench
After reading the above post.... MAN, AM I GLAD I AM IN FLORIDA!!! YAY lol
NO LONGER A MEMBER
The Lake
I think I'll jump in here. This is the first winter we will go through with our boat. The PO never winterized, he lived in Louisville and said he would just drop the boat in the lake every couple of weeks and run it. I'm in the Kansas City area, and will keep the boat in a heated garage. I was thinking of doing the same thing, just taking it out and dropping it in the lake and run the engine for 15 or 20 minutes. Yes the lake frezes over occasionally, but usually not for more than a couple of weeks at a time.
Any advice with this? Anyone else doing the same? |
79nautique
Guest |
usually you don't have to remove the belts. But in this case since he doesn't fogg, which I wouldn't recommend not doing, he removes the belts so that he can crank it over with out the antifreeze being pumped out. You really only have to remove the belt from the raw water pump and the thermo stat. If the circulation pump spins all it's going to do is move it around in the block. The extra water pressure from the RWP and a closed thermostat is what pushs the water to the exhaust manifolds. And really you don't even have to remove the belt from the RWP since you should remove the impeller for winter storage but since it's off no need to put it back just to take it back off come spring when you replace the impeller.
RobG
Newbie Joined: July-07-2005 Location: United States Status: Offline Points: 31 |
Tim,
Hope this isn't a dumb question, but why 'belts off'? |
Tim D
I would say seafoam is a valve and piston cleaner. I wouldn't use it to keep parts oiled, it would seem to wash off what oil is there. Any way, I don't fog, just every once in a while during the winter, I'll crank the motor a couple of revolutions, just to lube everything and yes the belts are off.
Tim D
stang72
Sea Foam...yes it is a top end cleaner...but has many uses...at least they claim so!
A mechanic buddy (who is a good one)uses it for foggong the engine...I have for a couple years and it has worked well!I stablize my gas,treat the oil and run it through the carb each fall...so far so good. |
dchris17
Gold Member Joined: May-28-2005 Location: Weatherford, TX Status: Offline Points: 573 |
I use Sta-Bil. It works fine for the gas.
79nautique
Guest |
I thought seafoam was a top end cleaner, well that's what I use it for. The Penziol makes an arisol spray called FOGING OIL which is what I use and you can get at any wal-mart in the sporting goods section. I don't know that I would trust it as a gas stabilzer.
stang72
It's just putting protective lubrication in...I use seafoam....poured in through the carb.
Seafaom...will work as a gas stablizer and oil treatment too...great stuff! |
limocpa
Newbie Joined: September-26-2005 Location: United States Status: Offline Points: 1 |
What does 'fogging the mortor and cyclinders mean when winterizing? thanks
