  New Posts New Posts RSS Feed - New Owner
New Owner
 Post Reply Post Reply Page   123>
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Topic: New Owner
    Posted: May-31-2012 at 12:49pm
Originally posted by Tiger76 Tiger76 wrote:
Hey guys thanks for all of your help. I've taken the boat out 4 or 5 times with no more leaks, but I'm noticing after making a few pulls and sitting a few minutes that the boat doesn't want to idle well and goes dead alot. Any ideas on this one would be much appreciated.
When this happens, and it starts, do you get any black smoke? Sometimes the carbs will keep dripping after shutdown, and then load the engine up with gas. This would indicate a needle&seat issue or rebuild.
Run the boat at speed, then slow down in neutral and leave it running. Open the engine cover, then remove the plastic carb cover and flame arrestor (be careful of pulleys etc.). When you can get a clear look down the barrels of the carb, shut the motor off. You should get little to no dripping out of the booster venturis. If it keeps dripping, then you're loading up with fuel and causing problems.
Replacing your flame arrestor bolt with one of these Thumbscrews will make removing and replacing your flame arrestor much easier.
Tiger76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tiger76 Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2012 at 7:58pm
Carb yes. The rest I'm not sure only owned it for a few months. How do I check on the ignition? Spoke to a friend of mine that is fantastic working on cars and he said he could rebuild my carb with extra parts he had from drag racing so it would be high end stuff.
93 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2012 at 12:59pm
Tiger, I actually lost track of your setup. This is a carbureted boat? Protec ignition or traditional?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tiger76 Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2012 at 9:33pm
How often should the carb be adjusted?
93 Sport Nautique
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2012 at 8:02pm
Carb & ignition! Start at one end & work your way thru to the other side of the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tiger76 Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2012 at 12:24pm
93 Sport Nautique
crobi2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote crobi2 Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2012 at 3:35pm
Hah! I knew I didn't have a clue!
My first car had a 318 in it. VERY strong running motor. Been too long for me to recognize it, but I should at least have noted where the distributor is. Then, the heads/deck shape tells you it ain't GM small block. Maybe then I could of at least guessed right. Oh well, that's what happens when you start writing before thinking.
C-Rob
2000 SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2012 at 3:28pm
Originally posted by crobi2 crobi2 wrote:
That's a pretty boat. I guess that engine is a 302 or is it a 289? Showing the gaps in my knowledge.
It's actually a Chrysler 318 and painted the wrong color!
Post Options Post Options   Thanks (0) Thanks(0)   Quote crobi2 Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2012 at 3:26pm
C-Rob
2000 SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2012 at 2:06am
Nice find, cool looking boat
defsc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote defsc Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2012 at 12:48am
haha I sold a yellow ATV to get this boat. I was looking for a bass boat and saw this. I've always wanted a ski boat and love the sound out of these old classics. It was completely restored like 5 years ago and the last owner kinda let it sit to long. I'm picking it up Saturday cant wait to start scrubbing it down!!
1969 barracuda
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tiger76 Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2012 at 11:27pm
Looks nice. I love yellow, had a yellow silverado and Honda CBR.
93 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote defsc Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2012 at 10:45pm
1969 barracuda
Post Options Post Options   Thanks (0) Thanks(0)   Quote defsc Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2012 at 10:24pm
1969 barracuda
Post Options Post Options   Thanks (0) Thanks(0)   Quote defsc Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2012 at 7:21pm
I boat in Acton Maine. I live in Tewksbury MA.
1969 barracuda
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2012 at 2:02pm
Originally posted by defsc defsc wrote:
I'm also a new owner. just bought a 1969 barracuda any important things I should know about this boat? my first boat I live in Maine cant wait to get it in the water!
What part of Maine do you boat in?
As far as things to know...hmmm. Make sure you've got oil in the engine, fresh gas in your tank, a charged battery. Make sure that any parts of the cooling system that were taken apart for winterization are put back together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote defsc Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2012 at 12:31am
thanks. I'm having trouble trying to start a diary so i can get some pics of my boat up.every time I submit my info its saying there is some error on line 125.
1969 barracuda
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tiger76 Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2012 at 11:51pm
Congrats on your boat. This is my first boat and I'm learning alot from all the great people on this site. The first time I put mine in the water I had to adjust he packing around the shaft because it was a pour not a drip every 7 seconds. Check for other leaks water, gas, oil and tranny fluid. Make sure prop spins freely by hand and prop shaft looks good and straight. Enjoy everyone checking out your toy...
93 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote defsc Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2012 at 10:29pm
1969 barracuda
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tiger76 Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2012 at 1:53pm
Replaced tranny hoses and spark plugs this past saturday. Maybe I can put it in the water this weekend to give it another go.
93 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tiger76 Quote  Post ReplyReply Direct Link To This Post Posted: April-11-2012 at 12:10am
Well the tranny return hose looks to be leaking still. I can see 0/01/90 printed on the side of the hose. Do you guys think that the hose could have been made in 90? If so I'm gonna go ahead and replace both just to be safe.
93 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tiger76 Quote  Post ReplyReply Direct Link To This Post Posted: April-10-2012 at 12:37am
Put my new winch strap on this evening and installed my new fuel guage that I ordered from nautiqueparts.com
Thanks for the sticker
I also fired up the boat on my new free fake a lake and let it warm up and run 5-10 minutes and didn't see any leaks from the tranny. Will check again in the morning, but all still looked good 1-2 hours after running.
93 Sport Nautique
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: April-05-2012 at 4:50pm
Haha go figure I'd spell something wrong, but that was a funny one to get wrong.
Now back on topic I'm using the winch strap. As well as two other means to keep the boat on the trailer. Is this just over kill.
no, not overkill, I think you are on the right track wiht the winch, turn buckle and straps at the back, you should be good to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: April-05-2012 at 10:10am
You shouldn't run the tranny when out of the water it's hard on the cutless bearing and the driveshaft seal.
As for launching...I launch in a river that has a pretty good current what I found helps is don't put your trailer so deep. Back in till the fenders are just above the water, that way they will help guide the boat off and on.
Once at night(in a hurry) I put it too deep and when I pulled it out the current had pushed it to one side of the trailer and it ended up on top of the edge of the fender and smashed the fender and took a chunk of gel out of the bottom edge of the boat. DON'T DO THAT!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tiger76 Quote  Post ReplyReply Direct Link To This Post Posted: April-05-2012 at 1:19am
93 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: April-05-2012 at 12:56am
I have the wench strap ....
Just for clarification:
Wench: Verb:to associate, especially habitually, with promiscuous women
Woah.
now a winch strap I understand , and I do use one on the front of the boat.   probably a part to be replaced every couple years so you don't run the risk of breakage.   Also probably good to carry a spare if you are using this as your primary method of holding the boat down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tiger76 Quote  Post ReplyReply Direct Link To This Post Posted: April-04-2012 at 9:40pm
Used a small bit and hand drilled as you instructed and now water come out like a jet.
Was also wondering if you guys strap down the back of your boat to the trailer?
I have the wench strap and added a turn buckle to the front and have been running a ratchet strap across the back but was just wondering if the back strap is needed. The guy I bought from only ran the wench strap. Funny because my third trip the strap broke away from the hook while loading due to the age of the strap.
93 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: April-04-2012 at 12:29am
If you're using a syringe to back flush the pitot and you are getting dribbles then you've got blockage in there somewhere. Water should come flying out of there like a squirt gun. I've used a small fish hook to dig in the hole at the base or use a drill bit smaller than the hole and hand drill it till you free up the debris.
Brian, the tubing was actually laying round the shop for a couple of months as someone ordered the wrong stuff. We needed hard plastic tubing for a job not rubber so I found a use for it.
We use syringes all the time at work to inject resin into parts or for small applications where we use them like a baker would icicing to apply resin to small bushings or inserts where you don't want a huge mess or applying resin on parts similar to a caulk gun.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tiger76 Quote  Post ReplyReply Direct Link To This Post Posted: April-04-2012 at 12:10am
Morfoot I worked on the speedo this evening and now I'm able to get water to come out of the tip on the end but very little is this correct or should it flow out?
Ordered my new fuel gauge and I also took two hammers and was able to straighten out the prop in about five minutes.
A buddy of mine is giving me a fake a lake tomorrow for free so I'll be letting you guys know if I got the tranny fixed.
93 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tiger76 Quote  Post ReplyReply Direct Link To This Post Posted: March-31-2012 at 4:22pm
Thanks for the pics. Gotta find some more time to work on it.
93 Sport Nautique
