  New Posts New Posts RSS Feed - 2002 super air
2002 super air
Ed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed Quote  Post ReplyReply Direct Link To This Post Topic: 2002 super air
    Posted: April-15-2012 at 5:10am
I didn't think about that!!, I think that you are right!
mike32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike32 Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2012 at 5:02am
I think the buttons are for a power hatch release that is no longer there.
Ed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 10:40pm
No problem, it's a cool boat! I remember when they came out!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike32 Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 10:31pm
I will take a pic tonight and post it also of the wires hanging, thanks for the help, I went from a 92 ski to this and I'm blown away by all the gadgets.
Ed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 10:21pm
I realize that, one of those wires may come from the shower button, the boat is prewired.
Ed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 9:48pm
Mike,
Check the automatic fire extinguisher button too. Check both those wires aginst the switches. Those other buttons are for some sort of auxilary. Maybe extra ballast like phat sacks or something, we'll figure it out!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike32 Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 9:44pm
I dont have the shower option, just the button.
Ed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 9:31pm
Turn the shower button on, and check voltage on the orange and black wire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike32 Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 9:16pm
yes it has a button on the dash for heater and shower. there are two small buttons on the sides near the rear seat and two that are accessible from the swim platform. I thought they were for lights but they aren't, the wires are red coming off of them and they are in the original harness.
Ed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 9:06pm
I'm not quite sure about the buttons, I'd have to see a picture. Another thing to think about, those boats came prewired for heaters and showers. You could eithe use a multimeter or test light on the wire. That boat has a shower and heater button on the dash, right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 8:56pm
Originally posted by mike32 mike32 wrote:
Also what are the chrome buttons for around the boat, they dont seem to do anything?
Snaps? The boat had a cover at one time!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike32 Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 8:49pm
One has a black tracer. Also what are the chrome buttons for around the boat, they dont seem to do anything?
Ed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 6:46pm
"tracer", sorry
Ed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 6:11pm
Do those wires have a trcer on them or are they just solid orange? I used to have a full schematic from '01, but I don't anymore. I have a friend that does though, I'll see if I can get my hands on it for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike32 Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 5:44pm
the two orange wires are right below where the starter relay is on the back of the motor just above the trans.
Ed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 5:11pm
That is your v-drive overheat warning light. Where about are the orange wires?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike32 Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 1:15pm
What is the red light next to the key pad that says "if this light remains on above 1200rpm dont use boat" I have mine on water in the garage and that light is on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike32 Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 1:12pm
I also need a diagram that shows motor area wiring I have two orange wires that have been cut and are hanging.
Ed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 5:08am
Correct Craft from the factory would build a harness for the speaker wires and run them into a 10 or 12 pin male connector. They would then put the female connector on the speaker wires coming from the head unit and connect them together. Are you just trying to identify the speaker wires so that you know front and back, right and left? You mentioned an existing amp, is it conected? Previous owner install? Post some pictures, I think that I can help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike32 Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 4:03am
No I think it has all been changed in ghetto fashion, I need a diagram so I can correct the problems and use the amp that is there.
Ed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 3:43am
I don't have any diagram, I'm just familiar with the boat. Are you looking at adding an amp? That boat has the large Clarion head unit, right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike32 Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 3:29am
a wiring diagram that shows everything for the speaker wiring. I guess a full factory diagram for the boat.
Ed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 3:08am
what exactly are yo looking fo in the stereo wiring?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike32 Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 2:24am
Does anyone have any wiring diagram for this boat that shows the stereo wiring, or is there a site that I can find this info? Thanks for an info. mike
