  New Posts New Posts RSS Feed - first time change oil in my 1983 2001
woodlandsnautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodlandsnautique Quote  Post ReplyReply Direct Link To This Post Topic: first time change oil in my 1983 2001
    Posted: April-29-2012 at 1:44pm
Thanks guys mission complete, went with the wix and vr 1
1983 Ski Nautique 2001
FUN-9C1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FUN-9C1 Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2012 at 1:58am
BTW, the 20-50 weight is what most go for.
Pete, what's the reasoning behind the 20-50? Why so thick?
The viscosity is not "thick". Keep in mind it's the lower number of a mutiweight that is the actual viscosity. The higher number is what the oil viscosity acts like at the engine operating temperature.
I believe the manual calls for straight 40 under some operating conditions.
What are you using?
I use 5-30. I was just using the word "thick" as a layman's term, as a higher viscosity is "thicker" at any given temperature.
My manual calls for 40W for 90 and above which is rare here in NH. Calls for 30W for 0° to 90°. My feeling is I want the lowest viscosity I can get for the "cold" viscosity (the "lower" number) since even 0W cold is "thicker" than any hot motor oil. Ideally the oil would be as "thin" cold as it is hot, but that hasn't been invented yet. Outside temp doesn't mean squat to the "hot" (higher) number since once the motor is hot, the oil is basically engine temp which is not affected by outside temperature.
Go for the recommended viscosity for the "higher" number and the lowest available on the "cold" number.
'86 2001
'50 Century Imperial Sportsman
jimsport93 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimsport93 Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2012 at 1:08am
Had to download that link so I could study up!
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2012 at 12:28am
I almost Fouled my Abaft when I saw no listing in the glossary for Slalom, Trick or Jump.
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2012 at 9:32pm
Originally posted by Morfoot Morfoot wrote:
a Petetionary
I think I get it now. You could only have 1 copy though...
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2012 at 9:28pm
You'll never guess who uses the "garboard" term all the time now since he's gotten into the wood boats!
I bet I would.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2012 at 9:24pm
Originally posted by BuffaloBFN BuffaloBFN wrote:
I didn't see 'garboard' on that list.
Greg<
I didn't ether. It was the first word I looked for too. When I googled for the list, plenty comes up.
Okay, I'll refer back to my original statement and say we need to start a Petetionary.... here's the second entry.
A Brainard - the art of riding behind a classic Correct Craft in an innertube wearing a monogrammed long sleeve button down shirt.
" Wow, did you guys see that? Hollywood just did A Brainard behind Reid's Mustang"
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2012 at 8:56pm
Greg<
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2012 at 7:55pm
Times do change Pete. Abeam means butterslide now, but only if the entity off of the boat is in contact with the water's surface.
ABEAM - At right angles to the keel of the boat, but not on the boat.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2012 at 4:47pm
What are you using?
Post Options Post Options   Thanks (0) Thanks(0)   Quote FUN-9C1 Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2012 at 4:30pm
You should have the hose that will go through the garboard drain. If not, then the best way is to suck it out with a vacuum extractor.
'86 2001
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2012 at 10:48am
Got a lawnmower? That is where I use all of my odd oil up.
I looking for an opportunity to use a new word, btw.
Maybe you can store the extra Castrol in your lazarette?
TRIP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRIP Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2012 at 2:57am
A related question: what about Castrol GTX oil? ZDDP OK? I normally use VR1, but happen to have a few quarts of GTX laying around so would like to use it. Yay or nay?
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2012 at 2:23am
Greg and Tim,
here's some homework for you guys!
Clearly they did some research!
"ABREAST - Side by side"
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 11:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 11:07pm
The term is used more with the wood boat group but still applies. It's next to the keel!
A garboard is: "The first range or strake of planks laid next to a ship's keel."
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 10:59pm
If it doesn't have the hose set up get yourself one of these.
http://www.fumotousa.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 9:49pm
Maybe we need to start a Petetionary?
What fer? And I think you spilled it wrong.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 9:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 9:33pm
garboard drain.
I just learned something; been calling it a bilge drain.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 6:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodlandsnautique Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:39pm
Awesome, drain plug at the bottom Im guessing, wonder if there is a hose to help with dainage. Ill use that VR1 and the Napa Gold. I wonder how much to put into it, I guess add and check, add and check
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:30pm
If you don't have the manual, the PCM engine manual is in the reference section however, the oil change is pretty simple. The only thing you really need to know is to use a oil with a high ZDDP content for your flat tappet engine and a good filter. Many here run Valvolene VR1 off road since it's got the ZDDP needed. Good filters include Napa Gold or Wix (actually the same filter). Stay away from the Fram filter! Seroiusly!
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodlandsnautique Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2012 at 5:15pm
I'm not sure if I have the manual of not, but wondered what type of filter to get and type of oil to get. Im guessing, you drain the oil and then replace filter, anything different on a boat, first time to do so since owning it.
