  New Posts New Posts RSS Feed - Oil pressure sending unit
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: Oil pressure sending unit
    Posted: May-06-2012 at 5:34pm
Mark,
What testing did you do that indicated to you the sender was bad requiring it's replacement?
marmon77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marmon77 Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2012 at 5:14pm
No teflon tap on gauge going to block, and I haven't been messing with the wiring behind the dash, so I'll remove the wire and test it that way. The sender is new so I wouldn't think it would be bad buuuut you never know. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2012 at 9:30am
Mark,
Remove the gauge sender wire (at the sender itself is easiest) See if the gauge still pegs. If it does, then yes, the sender wire is shunted (shorted) to ground. If it doesn't, with the sender wire still disconnected, Ohm between the sender terminal and ground (engine block). If you get a near zero reading the sender itself has an internal shunt to ground. Replace it. (a battery powered test light will work too - if it lights up, then the sender is shunted)
Teflon tape on the sender pipe threads may cause a open circuit because it may insulate the sender to the block. The block is the ground for the gauge. If this was the case, you wouldn't get any gauge reading.
BTW, has anyone been doing any wiring on the back side of the dash?
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2012 at 12:05am
Did you use anything like Teflon tape? I hear the unit needs direct electrical contact with the block.
1987 Ski Nautique
Big t View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big t Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2012 at 11:58pm
Mabie atheist sender wire is frayed and grounding some where between the sender and gage? You could temporarily add a cheep mechinacal gage to see what the pressure is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote marmon77 Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2012 at 11:19pm
I replaced my oil pressure sending unit but the gauge still pegs all the way to the right when the boat is on. Your thoughts? Thanks
