  New Posts New Posts RSS Feed - 1994 SN Engine Hesitation first time out..HELP???
nstomy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nstomy Quote  Post ReplyReply Direct Link To This Post Topic: 1994 SN Engine Hesitation first time out..HELP???
    Posted: May-21-2012 at 12:55am
Don't think so.
I changed the fuel filter, again, cause of a hunch my mechanic had about faulty filters collapsing and what not.
All I know is now I have a happy 8 year old, can't beat that. Got him in the course this morning, he is hooked as I was. Awesome.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2012 at 11:04am
Was it the anti siphon valve then?
Post Options Post Options   Thanks (0) Thanks(0)   Quote nstomy Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2012 at 12:38am
Fixed, runs well, so happy. Life is Good. Thanks to everyone who had advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nstomy Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2012 at 11:25am
Well, I have changed all the normal jazz in plugs, wires, fuel pump, filter, and no luck.
I had it out on the lake yesterday and decided to look at the antisyphon valve......I think I had the right part inhand, is this the anti shypon valve?
Other than that, I am out of options until I get the Protec system I bought on the parts section. Should be here next week. Any advice once I get the parts in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote nstomy Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2012 at 2:18am
Ken,
Didn't check this thread yesterday. I purchased the whole system from Racer447 over in the parts for sale section.
Thanks for the reply though,
Nick
Originally posted by skibayer skibayer wrote:
Hi Nick,
I changed my 94 351 PCM Protek EFI to single port injection quite a few years ago. I have all the parts including intake manifold, computer, fuel pumps, throttle body assembly, etc. that would like to find a new owner. It worked properly when I did the conversion. Let me know if you are interested and I will get you some pictures to be sure it is the right stuff.
Thanks,
Ken
Foot_Fungus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foot_Fungus Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2012 at 2:03am
skibayer - if he isn't or only needs that sensor I'd be interested in some of the other parts for spares.
skibayer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skibayer Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2012 at 8:57pm
Hi Nick,
Thanks,
Ken
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2012 at 1:09pm
The Protec EFI stuff is pretty rare I think. Your best bet is to find someone on here (which is prettly likely) who has done the conversion to Carb and distributor and hope that he didn't throw all the Protec stuff away.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nstomy Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2012 at 12:06pm
Originally posted by nstomy nstomy wrote:
Anyone know where I can get an Idle Control Sensor?
You may want to post in boat parts wanted. If someone did the retrofit and happened to have the EFI version of the Protec, then you might luck out. Did you try Skidim?
I have and no luck, the part needed must be named something else cause I can't find what I am looking for anywhere. It is on the port side of the throttle body, and I was told that (Idle Control Sensor) was what it was called. I brought the boat home this week so I will take a picture later to post for reference.
I am sorry the part I was told to check on is on the Starboard side of the throttle body..... a little slow this Monday morn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nstomy Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2012 at 12:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2012 at 12:39am
Post Options Post Options   Thanks (0) Thanks(0)   Quote nstomy Quote  Post ReplyReply Direct Link To This Post Posted: May-12-2012 at 7:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foot_Fungus Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2012 at 1:58pm
Peter, sorry this stupid iPad keeps messing up the link when I try to use the hyperlink button. I'm too cheap to buy the app it says need to view correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2012 at 1:18pm
One free thing that you can do while you're waiting for you parts is to clean up all of your wiring connections. It never hurts and it just might help. Anything that will easily come apart or unscrew, you can hit with one one of those brass tooth brushes, or some emery cloth or sandpaper. Then re-assemble with a little dialectic grease.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nstomy Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2012 at 1:06pm
Went ahead and got a new fuel pump (never been replaced), new fuel filter will change this weekend. I will get the plugs and wires to change as well. Will update once complete. Thanks for the help guys, it is good to know that there is a website out here with people so willing to help. I don't have a Correct Craft dealer within 3 hours.
Again Thanks..
Nick
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2012 at 9:06am
Originally posted by Foot_Fungus Foot_Fungus wrote:
ah good catch kapla, forgot all about the carb lol.
Bri that engine has the gt40 heads on it. The stock plug on the ProTec is the Autolite 764. I ended up running the NGK version which is BPR6EFS, for no other reason than I prefer NGK plugs.
stomy if you haven't done the wires in a few years it would probably be a good idea anyways. Here is a link to WhiteLake's site with the wires.
http://www.nautiqueparts.com/plugwiresetpcmprotecengines.aspx
SkiDim sells them as well:
http://www.skidim.com/prodinfo.asp?number=RA121040
John,
Still having problems with the links??? For the convenience of all, here are the proper links:
Nautique parts plug wires
Skidim plug wire set
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foot_Fungus Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2012 at 1:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote nstomy Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2012 at 1:21am
Thanks!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2012 at 1:19am
The plugs aren't necessarily marine specific. You can find the ones that apply to you here:
http://www.skidim.com/products.asp?dept=1023
You most likely want the Autolite 24s, if you have the standard heads. Do you knoow what hp you have? Higher hp suggests different heads.
The wires are marine spefic, mostly because or the length to get around the exhaust manifolds. The protec systems use a special wire set.    http://www.skidim.com/prodinfo.asp?number=RA121040
Not sure if you'd want to buy the special set if you were planning to ditch the Protec? The retrofit kit would come with it's own set, which is more like the normal set.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nstomy Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2012 at 12:34am
Thanks for the responses. I will have to check everything Friday, for the boat is in storage at the lake.
On Friday the boat ran like a top until it "warmed up". Same on Sat. Sun was well just miserable.
This may sound ignorant but can I use automobile spark plugs and wires or is there marine plugs and wires?
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2012 at 12:18am
around $1000 as it also requires to ditch the efi and retrofit to a carb system
<a href="">1992 ski nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foot_Fungus Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2012 at 10:49pm
there is a guy in the for sale section selling off his complete pro tec system, and I usually see the coil and "dizzy" on ebay every now and then. The coil pops up fairly frequently as it had other applications. Retrofit is gonna set ya back about $500.
1600rpm does sound like limp mode, but your hesitation at 35mph at the beginning of the day leads me to think you have a coil or ignition signal issue. On a regular distributor I'd say time for a cap and rotor. On these fake distributors it either works or its bad. Which is why everyone trashes the whole system and retrofits it with a standard ignition system. I'm not sure on a testing procedure for the protec wannabe distributor, but you could test the resistance on the coils like you would normally, generally speaking coils will crap out once they get hot. Easy way to test without a volt meter is let the boat cool all the way down then go out and see if it runs normal until it heats up or if it still misfires(I believe you'll need to unhook the battery to reset limp mode). If it runs normal at first then gets worse as it heats up my money is on the coil, if it is dead cold and still runs like crap then probably isn't the coils. Of course I agree with the above I'd first check the basic fuel filter and spark plugs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2012 at 10:16pm
yup protec and injection, if the problem is the protec, the only solution is to retrofit the whole thing to a conventional distributor and carb system...
michiel200 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michiel200 Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2012 at 7:35pm
Protec?
'92 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2012 at 5:43pm
I would certainly check the basics, clogged filter, or antisyphon valve at the tank.
The 1600 rpm looks like the limp mode. how old is the gas you are running?
Post Options Post Options   Thanks (0) Thanks(0)   Quote nstomy Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2012 at 1:21pm
Hello,
I am a new owner of a 94 SN. First time out on the boat this past weekend exposed an issue, at first it ran fine, then it started hesitating and losing power at around 30-35 MPH. At the end of the weekend I couldn't get the boat past 1600 RPM with out hesitation.
Anyone know what the issue could be? Fuel filter? clogged syphoning system? Motor is the PCM 351 PRo Tec EFI.
Any help would be appreciated, I promised my 8 year old he could ski this coming weekend...don't want to disappoint.
Thanks,
Nick
