89 dash board replacement |
Page 12> |
wmoorev ![]() Newbie ![]() Joined: December-28-2017 Location: Baltimore Status: Offline Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: March-20-2020 at 8:03pm |
Looks TERRIFIC!
Well done! |
Cam05210 ![]() Groupie ![]() Joined: July-27-2009 Location: Charlotte Status: Offline Points: 40 |
Well...after a few months of hecticness and some back and forth, I finally was able to pick up the boat yesterday from my shop. Summary....was doing a top to bottom restore over the fall and had a small crack in the dash panel...I found a non OEM on nautiqueparts and was set to replace it. Upon taking the panel off, I realized all of the buttons were hard wired through the panel and of course, I broke the OEM as I was taking it apart (very fragile after 30yrs) so this left me with having to replace not only the panel, but all of the switches and indicator lights. When we went to put it together, the panel I was sent did not fit quite right and left spacing on either side. I scoured the internet and across the US trying to find a replacement with no success. Then I came across TJ's information who had created the files to have this panel reproduced which I sent to a local fab shop.
Fortunately, they made 2 of them for me out of acrylic and looked awesome. I say fortunately because with the nature of the acrylic, when the tech went to install it, some of the backing chipped off causing some minor imperfections. So we used 1 for test and the second for final application. While there were still some tiny spots that still gave us a fit being very OCD...we moved forward with the full install as even the minor blemishes were much better than what it was. Knowing all of this now, I'd recommend having the fab shop use a different material, but it looks awesome and at least keeps the OEM look that I was looking to maintain. Here are the before and after pics: ![]() ![]() ![]() |
This is excellent news! I am anxious to see the result achieved, as I am needing one as well.
I do have a piece of plate aluminium that I have recently acquired, with expectations to have it powder coated black, ad then have the lettering and logo cut into it. I may consider abandoning that track if your end product is particularly nice. I look forward to seeing how it turns out. Thanks for the post! |
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21198 |
How will it compare to the original? Please post pics once you have it.
Can they work off an original or only CAD? I have a 87 panel that I’d like to see recreated. |
I can't thank TJ enough on providing the files. I've searched far and wide and think I've called just about every parts place I could come up with to no avail in an attempt to get an OEM dash plate.
I have sent this over to an acrylics fab shop here in Charlotte to reproduce in black with white lettering/stripes...It will be about 2 weeks but I'll post results so if anyone needed this panel, you'll have a place to call. $145 was the total price with paint. |
TJ, I'm sure many will appreciate your work. I'm reporting this post to Keith so he can put it in the reference section. Thanks. |
1989SN2001 ![]() Senior Member ![]() ![]() Joined: October-01-2010 Location: Canton, GA Status: Offline Points: 122 |
About every 6 months I get a request for these files in my email, so I'm just going to post a link here. This is everything associated with the dash I made. There are 2 versions of the file, one labeled "original" which includes the holes for the indicator lights, and one that omits the lights and has a cutout for a Clarion CMS1 stereo module. I think this stereo is discontinued, but others may fit the same cutout pattern, you'll have to check.
Files were originally made in solidworks, I just went through and added .dwg, .dxf, .stp, and .x_t files. This should allow it to be imported into just about any other CAD software for manipulation and tweaking. I left out a few of the mounting holes and drilled them by hand to match my dash pod, so there is no guarantee that the mounting holes will fit your dash. It seems like this is something that was done by hand at the factory and no two boats are alike. Anyone with this link should be able to download the zip file with all of the CAD. Feel free to continue to email me with any questions. https://www.dropbox.com/s/rh7pa16qt2egdtq/1989%20CC%202001%20Dash%20Panel.zip?dl=0 |
Bubba717 ![]() Newbie ![]() Joined: July-22-2019 Location: PA Status: Offline Points: 1 |
Would you be able to send me a copy of the file for the dash panel? DWG file would be great.
Let me know if that is possible, thanks Dustin |
1988 Ski Nautique 2001 351w
Greetings - I have a 1988 Dominique, an I also need a new dash. The pictures of the aluminum fabrication in this thread look identical to mine, but without the holes for the lights of course.
Does anyone have any current information about a replacement dash in either aluminum or plastic? If I have no luck, I have a half baked idea of making one out of teak, as my boat has wood rails on the inner sides. Any help would be sincerely appreciated! Happy New Year! - Willy - |
mark c ![]() Gold Member ![]() Joined: May-09-2012 Location: Massachusetts Status: Offline Points: 534 |
What's the difference between same year (or series) SN dash plates and a BFN dash plate besides the label?
Foot1n ![]() Newbie ![]() Joined: October-15-2016 Location: Georgia Status: Offline Points: 3 |
Christine's is out of BFN dash plates. Mine is in desperate need.
Man I want one. That is impressive. How much $????
Yes, I have everything dimensioned out, send me an email and I can get you a file of the original and my modified version.
tjgray347@gmail.com |
dochockey ![]() Gold Member ![]() ![]() Joined: September-16-2009 Location: Colorado Status: Offline Points: 638 |
Did you say you had the dimensions already laid out?
1989 Teal Ski Nautique
1967 Mustang Harris Float Sunfish |
I decided to leave the lights out on mine completely. They were a major contributing factor to the wiring clutter on the panel. Plus, I rarely boat at night and can't see them during the day anyway. If I change my mind later, I can always drill the holes for them.
The square corners of the horn opening had to be cleaned up with an 1/8" end mill and then squared up with a file after it was taken out of the mill. |
lewy2001 ![]() Grand Poobah ![]() ![]() Joined: March-19-2008 Location: NSW Australia Status: Offline Points: 2234 |
Chuck if you have a look at my conversion you will see that I replaced indicator lights with led's. Just need to wire in series with appropriate resistor I think it was a 670 ohm from memory.
How does the cnc handle the square corners for the horn smaller bit? you are not going back with the red lights ? after I cut mine out Ive been dreaming at night on how I'm gonna put it back together ? I've been searching for quick connects but havent found the right ones yet.
fanofccfan ![]() Platinum Member ![]() ![]() Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1796 |
That really looks nice. Always impressed by men and machines. Good job.
I'll post up the DWG and solid model and a PDF with dimensions in the next couple of days. Should I pass this along to Keith to put in the reference section?
Well I got it cutout last night. Much thanks to the best damn CNC programmer I've ever known, Brandon. Overall it took about 5 hours, including programming time, locating the right stock, and finishing.
The only thing I would do different on a second one would be to go a little lighter on the engraving for the switch labels. We only had table space for 3 toe clamps, so the center of the piece bowed up slightly, causing the left hand column of switch labels to be deeper than the right side. Rather than leave it like that, we decided to go deeper on the right side as well to match. Anyway, hope its acceptable. The Correct Craft script was about the closest I could find to the actual logo. I cant wait to get it installed. The setup fixture: ![]() Top and bottom profiles cut: ![]() Correct Craft script engraving ![]() Final product: ![]() |
Its looks like were making progress I finally got mine off but in doing so I had to cut some wires which I did not want to do. I'm thinking of wiring it back up with some type of quick disconnect so if I ever need to take apart again it will be easy.
Lew is it possible I can get a copy also ? My E-mail is dochockey at aol dot com thanks Kirk |
It was drawn in SolidWorks, which is what I do all my design work with at my job. Pretty neat program.
BigByrd ![]() Newbie ![]() Joined: July-14-2011 Location: Katy,TX Status: Offline Points: 26 |
Lewy,
Would you mind sending me the file as well? ryan.byrd@colliers.com TJ, What program did you draw that in? It looks sweet |
1988 Ski Nautique
ultrarunner ![]() Platinum Member ![]() ![]() Joined: October-02-2005 Location: Ridgefield, Ct. Status: Offline Points: 1867 |
Yes, these panels would be nice back lit. In the aircraft I fly, they are called EL Panels. I think I have one from an upgrade that I could post a picture of. But essentially made of a translucent material that has a molded color on one side, and subsequently engraved, revealing the EL. Lights are then impregnated into the back of these panels in a few locations, thus spreading the light evenly throughout the panel. We control intensity a rheostat for each panel. I think very simple to make for our application on the boat, having just one panel.
hmmmm.... |
cboland ![]() Senior Member ![]() ![]() Joined: July-15-2004 Location: Atlanta, GA Status: Offline Points: 185 |
Backlighting would be very cool. I'm not sure about the logistics of how to accomplish and make it look really good, but the concept is really great.
Bud
1999 Sport Nautique |
I had not really thought about backlighting anything on the panel, I rarely boat after dark. Its aluminum and its just engraved, not cut all the way through. Maybe the engraving could be filled with glow in the dark paint? Hah.
I think it would work well if the panel were cut out of a piece of double layer plastic with one layer translucent and one layer opaque. Or out of clear lexan with a vinyl overlay. Then just backlight the whole dash pod. |
That is going to be really nice. Have you given any thought to back-lighting the switch labels, ala, an EL panel? I have often thought that would be a nice feature for night boating, for those of us out on the water at night.
More than once I have reached to turn off my nav lights so I can see better going into the lift, only to have pressed the ignition button. Any thoughts? |
Hopefully I'll be getting this cut out in some AL tonight or tomorrow after work. Gotta get our CNC guy a 12 pack and convince him to stay late for my "government work". I can provide anyone who needs it a copy of this file in 2D or 3D, in just about any format. |
tbeard ![]() Senior Member ![]() ![]() Joined: April-26-2012 Location: Fort Worth TX Status: Offline Points: 387 |
Yes please e mail me the PDF for the dash layout. I am looking forward to making some improvements to the boat while restoring it. Thanks...Tom
backn68@sbcglobal.net |
Thanks.......Tom
The old 2001 site had the dash layout in a PDF file. I could email it to you if interested.
Made mine at of white polycarbonate and used a black vinyl overlay to get labels etc. ![]() |
Page 12> |
