Holman Moody water pump |
SNobsessed
Posted: December-26-2015 at 9:00am |
If you get a spare impeller, keep it in an air tight bag to keep ozone from degrading it.
john b
Grand Poobah Joined: July-06-2011 Location: lake Sweeny Status: Offline Points: 3241 |
Thanks Gary!
1970 Mustang "Theseus' paradox"
If everyone else is doing it, you're too late! |
vondy
Platinum Member Joined: November-29-2007 Location: Dallas, Texas Status: Offline Points: 1116 |
Got the rubber star from Tractor Supply.
Eric I don't have any idea of what is available right now but the only thing I have not been able to get lately is the front cover plate. But that can be made since it's only a flat brass plate. Give Depco pump a call it's part number 96080-0080 and is a 2 piece seal. If your that far in it you might want to check a bearing supply for a bearing too. The number on my old one is C 5202 FF
wakeboardin2k4
Platinum Member Joined: December-14-2006 Location: Hopatcong, NJ Status: Offline Points: 1117 |
Gary- any knowledge of the seal that goes behind the impeller?
Part #10 on the parts diagram of the link you referenced. PS: I love this site. In 5 minutes me and my buddy went from no knowledge of the inside of this pump to being relatively knowledgeable on servicing this pump! Thanks guys! |
"I'm planning to bring my girl that rides on a trailer with me and leave my girl that complains about camping at home"
Coupler and spider |
Hi Jeff. First sit down before you start looking. The pump you had was most likely 11850-80. It was replaced by 11850-0711. I just googled it and saw it runs between 500 and 800 bucks! If your looking for the part that mounts on the crank pulley,you just might just have to have one made by a machine shop.I found the rubber star at my local Farm and Fleet those are standard Love Joy. I had to replace the shaft in mine,the key way was damaged and had a machine shop cut down a love joy coupler for the aluminium cast drive on the pump that was egged out due to the bad key.Do you have any parts of the pump at all?
Link to pump instructions Link Link I have no idea about these sources I just did a quick search, there is Depco pump you could try too. Maybe they have a replacement for the Jabsco |
connorssons
Platinum Member Joined: January-17-2009 Location: Michigan Status: Offline Points: 1414 |
Need jabsco waterpump and love joy plate and rubber star for H?M or where to find parts thx jeff
