  New Posts New Posts RSS Feed - Battery Terminal Connections
Big Pappa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Pappa Quote  Post ReplyReply Direct Link To This Post Topic: Battery Terminal Connections
    Posted: July-09-2012 at 2:46am
I just bought new battery and starter cables for mine and went with marine rated 1/0 awg. I had them made from www.genuinedealz.com and they were delivered to my house in just a few days.
winniskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote winniskier Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2012 at 12:34am
My plan is to replace the terminals with something heavy duty and buy a wire brush terminal cleaner so I can clean the heck out of the terminals and crank down on the connection. The only question I now have is the gauge of the wire so can buy the proper size. Any idea?
Jim
62 wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 62 wood Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2012 at 2:52am
Might not be as likely on a boat, but on my 4x4, I've had corrosion BETWEEN the battery cable wire and the terminal (this happened to be at the starter)where you couldnt see it.
64 American Skier
62 Classic..
73 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote winniskier Quote  Post ReplyReply Direct Link To This Post Posted: July-04-2012 at 11:30pm
The battery might be 5 years old, but it shows a full charge and the problem existed even when the battery was new. I expext the cables are as old as the boat.
Jim
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: July-04-2012 at 10:45pm
I'd replace your battery first and then go after the cables. I doubt the connection at the terminal is the problem. When you disconnect and reconnect you "wiggle" the battery or cable enough to get things going enough to work for a little while. How old is the battery and/or cables?
Post Options Post Options   Thanks (0) Thanks(0)   Quote winniskier Quote  Post ReplyReply Direct Link To This Post Posted: July-04-2012 at 9:05pm
Every year, I fully charge my battery, clean the posts and terminals, and attach the terminals to the posts with enough pressure to make them secure without distorting the lead terminals. This year I added dielectric grease to ward off corrosion. This year, like every year, the boat runs great for about one month and then refuses to start. The boat acts like the main breaker is off – no blower, no idiot light, no pump, etc. After wiggling the batter terminals and/or cleaning and reattaching them again, they all light up and the boat starts fine. There is no visible corrosion, dirt, grime, etc., that would explain the bad connection. If I tighten the terminals any more, it will distort and the open ends will meet.
Are there terminals with sturdier metal? Is it possible that the problem is in the cables? Any suggestions?
Jim
